Question about Chisel Software Stainless Steel Cross & Link Bracelet
Bracelet is to big
Well its about 3 links to big I need it resized
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
You can remove extra links. If you can't do it yourself, visit jeweler in your vicinity. You can also check out Baby Shoe Charms BabyShoeCharms com for more details.
Posted on Nov 03, 2014
    Habit-Forming:
  • 55 Answers
I think you should take help of your jeweler or you can visit cufflinks.
Posted on Jan 01, 2014
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
How to resize the bracelet?
Without a picture of the bracelet it is a little hard to be specific but there are usually little pins on the end of each link (look at the edge of the link (not the face against your arm or the face you see). Use a push pin (something very narrow - a paper clip is too big) to push the link pins out for one link. You may have to rap it lightly with a small hammer or mallet. You may also need to try the other end of the pin if it doesn't come out.
This will allow one link to be removed. Reinsert the pins and you are all set. You may want to take out a link on the other side of the clasp if more than one link needs to be removed to keep the clasp relatively in the same place on your wrist.
Good luck.
May 23, 2014 | Chanel Premiere Ladys H0452
How do I resize the bracelet on a 20/4131 (I think that is the model number)
Normaly you have at each piece of the bracelet to the side a little pin and if you push it troug you can get one piece away then you put te pins back in and you fixed it.
May 06, 2011 | JCPenney Armitron Sport Link Bracelet...
How do i adjust the band on my invicta 4898 is to big i need it to be shorter please help
To remove some links: If you don't have special tool, at least you have to have something really hard and thin (like the pin you use to post notes on the cork board). Put that pin in to the tiny hole between links where the bracelet pin is and then press/push it forward (follow arrow direction as shown on the inside of the bracelet links.) When the bracelet pin comes out at one end, pull it out of that end totally.
After removing one links, connect the two links from two sides by placing the bracelet pin back into the hole and push it to the other end.
Feb 16, 2011 | Watches
Resizing watchband on Renato Beast
If there is screw in each side- you have to use two screwdrivers simultaneously.
If not- read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Aug 12, 2009 | Watches
Need to resize watch braclet on a mens invicta watch
Job done!
Apr 02, 2009 | Watches
How to resize (remove links) from metal band on casio wtg900da8v
Job done!
Mar 21, 2009 | Casio Watches
Need instructions for resizing a Link Tag/Heuer Watch bracelet
Hello! I just went through the same thing. If you got the watch new, you can look in the box to find "mini" or "half" links included with the watch. There is no fine adjustment on the Link, but you can replace the larger links with the "mini" links to get the size closer. They are not quite half size, more like 65% of a regular link. So if you add one "mini" link and the watch is too big, you can then replace a regular link with a "mini" link to keep adjusting the size. I went to a dealer (Jared does this, as does Torneau...you talked to the wrong person) and it took about 5 minutes and was $15.
Hope this helps.
Jul 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Need extra bracelet lings for a Tag Heuer Indy 500
Hi.  I just received the Tag Heuer Indy 500 with steel bracelet today for christmas from my wife.  I'm a smaller man and had to take out 3 links.  I'd never sell this watch so if you would like them...just write. croscow@comcast.net
Charles Roscow Silver Spring, MD
May 02, 2008 | Tag Heuer F1 Indy 500 CAC111B.BA0850
Chisel Software Stainless Steel Cross & Link Bracelet Logo
88 people viewed this question
Top Chisel Software Clothing Accessories Experts
Da Doc
ray gallant
Are you a Chisel Software Clothing Accessory Expert? Answer questions, earn points and help others
