Question about Tablets & eReaders
What can i do if my pantech tablet freeze it only appearswould you like to shutdown but is freeze
Letters from a to l all of them not working
Hipstreet Flare 9" 8Go problems - YouTube
? 2:42
https://www.youtube.com/watch?v=gRqFYPyacCI
Sep 10, 2013 - Uploaded by Ivy Killa
This is what happen when i try to open my Hipstreet Flare 9" 8Go. ... All Comments (13) ... with a used tablet..in my opinion, if atablet cannot last longer than 2 months with the light ... did you try to factory reset it hold volume up and power, hold them until the menu pops up my just freezes when i try to reset it.Missing: letters ‎l
HipStreet - YouTube
? 5:17
https://www.youtube.com/watch?v=6MQSPJOVD4c
Jun 22, 2013 - Uploaded by RodneyDickson
WARNING - I will NOT be held responsible for any damages the ...Remove all; Disconnect ... shutdown on HipStreet logo screen when booting the Vektor tablet ... will show you how to solve the issue of your HipStreet Vektor 7 inch Deluxe ... How to fix android tablet hang-up, freezing & crashing problem ?Missing: letters ‎l
Hipstreet 9DTB7 - Flare Wont turn on (problem Solved ...
? 3:27
https://www.youtube.com/watch?v=3Isu15ZoLls
Apr 28, 2014 - Uploaded by Lenz Walters
Hipstreet 9DTB7 - Flare Wont turn on (problem Solved) ... ThisHipstreet Flare 2 Google-certified tablet features a 9" LCD ...Capture every moment and video chat with those you love using the built in cameras. ... +Lynn L'Heureux no light at all ? .....com/2013/12/hipstreet-flare-9-inch-android-tablet.html or ...Missing: letters
Dec 30, 2015 | Hipstreet Flare 9 inch Tablet with 8GB...
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
My samsung tablet 2 keeps freezing or turns off and was wondering why?
you can try a factory reset
1. shutdown the tbalet
2. hold volume up button and press the power button
3. when manufacturer logo come leave the power button but keep volume up button to get to recovery mode
4. in recovery mode use volume up/down button to navigate and the power button to select
5. choose WIPE DATA / FACTORY RESET than select YES .... wait a moment then select WIPE CACHE PARTITION
6. finale step select REBOOT
keep in your mind all data will be erased
Feb 23, 2015 | Samsung Galaxy Tab Tablet PC
How to dismantle pantech p4100
although the manual is referring to the back of the tablet as battery cover, they don't mention how to open the tablet. They want you to contact the Pantech repair centre if you want it fixed.
I sen could not find a solution on ifixit.com for your tablet.
Sorry
Jul 08, 2014 | Pantech Tablets & eReaders
My tablet sceen is white how do i fix it
possibly water damage. call and see if youre under warranty
Mar 02, 2014 | Pantech Element 4G LTE Android Tablet
Gave my Pantech Element away how to change owner name
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Nov 02, 2013 | Pantech Element 4G LTE Android Tablet
Juice spilled on it and now after reboot it has a white screen. I thought the pantech element android tablet was waterproof...is it damaged?
it's only water proof when all the ports - usb - earphone are closed
"The Pantech Element is waterproof against incidental exposure to water when all ports (incl. USB and earphone ports) are tightly closed, but is NOT designed or intended for in water use. Waterproof based on IP57 rating. "
see if it's under warranty to return defective
Oct 30, 2013 | Pantech Element 4G LTE Android Tablet
Fix a pantech element tablet with frozen touch screen
my tablet needs to be caliabrated I try to touch a letter and it wont work
Apr 16, 2013 | Pantech Element 4G LTE Android Tablet
Tablets & eReaders Logo
21 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
