Question about Samsung HLR5064W DLP Projection TV
Screen hdtv have a 50 inch Samsung DLP TV now projecting an upside down picture. I have taken steps to access the factory menu by using the remote and entering Mute-1-8-2-Power. I can select the DDP1011 menu item, but can't get further than this. I have pressed "Enter" and also "1" (the menu item number for DDP1011), but the only response i get is when pressing the "1", and the response in "Not Available". Any help is appreciated.
  • 7 Answers
SOURCE: hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Posted on Nov 10, 2006
Tritronic
  • 5 Answers
SOURCE: picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
Posted on Sep 06, 2008
SOURCE: CCA Values For Samsung TV
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Posted on Oct 17, 2008
  • 453 Answers
SOURCE: tv screen flipped over upside down
have u just replace the main signal board if so u need to contac a sansung service center , and ask for the code to puit normal
Posted on May 08, 2009
localwonder
  • 6784 Answers
SOURCE: My set is the SAMSUNG LHP5063W. I replaced the color wheel Sunday and got horrible colors. The Part number ordered was BP96-00674A The number on top of the color wheel top is L3 BP61-01687A but I do n
The new color wheel is different from the original. The original used an Air Bearing type motor. But the replacement type is a standard bushing type motor. There is a jumper on the rear of the DMD board that may or may not be covered with a paper sticker. Reposition the jumper to accommodate the new color wheel.
Posted on May 21, 2009
Samsung hl-s6767w timer reset. Can I reset using the menu option located on the tv. I have no factory remote
Yes, you just have to toggle manually using the plus and minus key as well as the channel up and down keys to navigate the menu
Nov 17, 2013 | Samsung HL-S6767W DLP TV
How do you get a full screen picture?
Hi press the MENU button on the front panel or remote to view the osd menu use the down arrow to navigate down to SIZE, here you can change the size or aspect ratio of the video display. also here is a link to the full manual for you tv> http://www.retrevo.com/support/Philips-50ML8105D-TVs-manual/id/277ag615/t/2/
please rate me i need 2 more to get my badge thank you........
Feb 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Speckles in dlp tv screen samsung 50" dlp
No they couldn't have replaced everything or did they Replace Light Engine? Because that is what is Bad on your TV if under warranty get it Fixed Now Light Engine is very COSTLY !!!!!!!!
Sep 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Screen blacks out on samsung DLP
It may be a loose conetion inside the set. Open and carfully check the conections.
Aug 20, 2009 | Samsung HL-S5087W 50" HDTV
Tv screen flipped over upside down
May 08, 2009 | Samsung HL-S5086W 50" HDTV
Samsung HLP5063W 50" DLP Projection TV has a 3 inch black band
Did you check the picture format and adjust for 16:9 in the menu?
Jan 11, 2009 | Samsung HLN5065W 50" Rear Projection...
How do I do a factory reset?
With the tv off, press on the remote Mute,1,8,2,Power
This enters the service menu.
The factory reset option is in there.
Aug 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Picture is upside down Samsung HLR 4667W 46 inch
May 31, 2008 | Samsung HL-R4677W 46 in. HDTV Television
Hlp4663w color wheel
Check
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 29, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLR5064W DLP Projection TV Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
