Question about Vizio E420VA 42 in. LCD HDTV
IT WILL NOT TURN ON
IT APPEARS IT HAS NO POWER. REMOTE OR MANUAL POWER SWITCH DOES NOT WORK.
I have a Samsung HTC 550 home theatre system. It's set to region one and I've tried everything to make it region free to no avail. I want to watch a region 2 DVD. Can you help??
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote. (if your player is already set to region 2)
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Turn off power from remote.
11. Turn power back on with remote.
Player is now Region Free.
or
Turn on with remote control without disc.
When message "No disk" appears, press on the remote,
ENTER,
8,4,2,6,9
ENTER,
If hack work after the second ENTER player will power off automatic.
When power on again this was region free, I can confirm now read region 1, 2 and 4.
Sep 08, 2016 | Samsung HTC-550 DVD Home Theater System
Remote for my hamton bay ceiling fan 70 inch model DL-4109S-01 won't work. How can I get it to work?
first off see if the remote is working
if it is a point in the fan direction is is probably infred operation. to check turn on the camera of your mobile phone and point the remote at the lens
if it is working then a white light will appear on the screen of the phone when you press on the remote on button and disappear when the off button is pressed
if that works then it will be in the receiver in the fan
Sep 05, 2015 | Hampton Bay Dryers
Sansui platinum plus tv
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
Jun 30, 2014 | Televison & Video
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
Movies2go MMDV70C dvd player doesn't work
Look here for manual:
http://akamaipix.crutchfield.com/Manuals/220/220MDV70C.PDF
Feb 19, 2009 | Audiovox MMDV70CB Car DVD Player
42mf231d/17 fails to turn off manually or w/ remote.
Magnavox suggests unplugging the tv for exactly 10 minutes to reset the tv---try that---or call the service number for assistance
Oct 25, 2008 | Philips Magnavox 42MF521D/37 Television
Ceiling fan
If the switch is "OFF" on the wall, the remote will not control anything. The power has to reach the receiver first. If it worked before you turrned the swich off, than one of two things. Either
A: You blew a circuit to the unit or
B: Your receiver went out.
First thing I would do is check that POWER is getting to the receiver.
Sep 06, 2008 | Universal Remote Control Hampton Bay...
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
TV automatically turns magic focus mode on when the power button is pressed on the remote and even manually.
I have this problem starting today. Unfortunately, others who have fixed it have done the following.
* Unplug TV for hours and it worked
* Buying manual switch to the outlet or surge protector and switch power off that way.
It appears that I'm in no mood to spend hundreds to get this fixed for hundreds of dollars and just going the Radio Shack route of buying a switch which would probably be more of savings. But needless to say, I hope that is the only problem I have.
Sep 27, 2006 | Hitachi 46F510 46" Projection HDTV
Vizio E420VA 42 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
