Question about Big Toys Boys Electric MotoTec Dirt Bike
Mototec dirt bike won't charge
Charged for 12 hrs andnbike won't turn on
MotoTec dirt bike has 3 setting for speed but each setting is under powered.. On high the bike might hit 10mph with 50 pound rider on asphalt.. Batteries are good and run forever on a charge. Fix?
You get what you pay for.
The setting for speed are 5,10,16 mph.
You want anything faster you would have to do major rewire of the bike to over volt and current on the motor and additional batteries - cheaper to buy a faster bike.
Sep 16, 2016 | Motorcycles
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
What could be the problem if my son dirt bike says its fully chaged but when he turns the throttle nothing happens
Did the socket the charger was plugged into actually have 120vac in the socket?
Or are you sure the charger is actually working? Is there a short so that the battery is draining as fast or faster than the charger is providing a charge?
Mar 27, 2015 | Razor Dirt Rocket MX350 Miniature Electric...
I purchase a black@decker digital worksite radio and it will not stay charged it suppose to stay charge for 12 hrs it only stay charge for 3 hrs or less i tryed everything i let it charge for the full...
it clearly said on the box it will play for 12 hours at 50% volume is your charger in good shape most people pull on the wire of the charger not good for it. Did you turn your radio off to let it charge? the last thing did you let the radio charge for a long time more than the manual said. this can cause the life of the battery to die sooner and not hold charge anymore.
Nov 03, 2009 | Audio Players & Recorders
Can't charge battery
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. The best thing to do is contact your dealer, as I think you won`t be able to charge the batteries on your scooter as they will have no power. Thething with scooters is to put it on charge when not in use.
Sep 01, 2009 | Golden Technologies Compass Electric...
1993 Kawasaki 750R - Charging issue - Weird!!!
i know this sounds silly ,but when you bought the battery had it been activated,new batterys are critical in their first charge and you cannot use a standare type automotve charger,if bought dry the battery needs to have the acid filled ,left to sit for at least 2 hours prior to charging,once it has sat for the 2 hrs with the acid in,the new battery will need to be charged with a "cteck"or similar type charger for at least 13 hrs before it can be put into normal service,what happened with yours i think is that sure you gave it a charge but it has only recieved a "surface charge"and will be usable for a very short time,it may recover for a brief period and go again untill the surface charge dissipates,(or in other words ..runs out of charge)best thing you can do with the battery is take it to a auto electrician and have the battery cycled and conditioned,this is not expensive to do and will give you piece of mind,after conditioning the battery shouldngive excellent service,i have the battery in my goldwing coditioned about every 12 months and i have the same battery that was in the bike when i bought the bike 8 years ago and still no electrical or battery problems(costs about $25 to get it done)once a year but that beats $280 for a new one...hope this helps
Jul 09, 2009 | 1990 kawasaki ZXR 750
Charging batteries
at a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life
Dec 21, 2008 | Golden Technologies Compass Electric...
Big Toys Boys Electric MotoTec Dirt Bike Logo
Top Big Toys Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Big Toys Cycling Expert? Answer questions, earn points and help others
