Question about ASUS MeMO Pad FHD 10.1" 16GB Android 4.2 Tablet - White
Factory reset asus - ASUS MeMO Pad FHD 10.1" 16GB Android 4.2 Tablet - White
Reset asus memo pad kow to factory settings?
If you cant reset your phone normally try hard resetting it.
  1. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  2. Afterwards unzip it to your MicroSD card.
  3. In order to turn the device off press the Power button for a short while.
  4. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  5. Afterwards unzip it to your MicroSD card.
  6. In order to turn the device off press the Power button for a short while.
  7. Select Clear User Data using the Volume buttons to navigate and Power key to select.
  8. When "Please remove installation media!" inforamtion appears on the screen remove the microSD card from your device.
  9. Success! The hard reset has just been performed.
If this doesn't work use the link below
ASUS ME176C Memo Pad 7 How to Hard Reset my phone HardReset info
Mar 17, 2017 | ASUS Tablets & eReaders
Where is the factory reset button?
You don't state which ASUS product you own, but most (if not, all) ASUS tablets don't have a button to reset the device. You can do a factory reset via the settings menu. Look for a 'Backup an Reset' entry.
Mar 09, 2015 | ASUS Tablets & eReaders
How do I do a factory reset when it only has reboot or recovery setting on the asus
You can do a factory reset via the settings menu. Look for a 'Backup and Reset' entry.
Mar 07, 2015 | ASUS ME176CX-A1-WH Memo Pad 7 7IN 16GB...
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
How do i restore my asus b121 to factory settings
  • Restart your ASUS laptop and press the "F9" key while the computer is booting up. This will open the boot screen. Select "Recover Windows to Entire HD" and press "Enter."
  • Press "Y" three times when asked if you are sure that you want to restore. The laptop will restore the factory settings. The computer will then shut down and start up again.
  • Approve the license agreement, then select your "Language preference." Enter your name into the box and click "Next."
  • Enter your password twice on the next screen and select "Next." Enter the time zone and date information, then select "Next." Select "Finish" on the next screen and the computer will reboot.
  • Read more : http://www.ehow.com/how_6960619_restore-asus-laptop-factory-settings.html
    Nov 26, 2014 | ASUS Eee Slate B121
    Forgot unlock code on my asus transformer tablet ,
    You will have to do a factory reset, you will loose all your personal data on the tablet. Should be hold vol- button while pressing the power button. On screen you will see recovery options, select factory reset (wording may be different) by pressing down to cycle through the menu and press vol+ to select.
    Apr 17, 2014 | ASUS Tablets & eReaders
    I want to clean my eepad prior or giving to my granddaughter
    The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
    Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
    Mar 05, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
    Gliches all the time. I have to reboot for it to fix. Can't leave Wifi too long or it will start messing up as well.
    Reset the device to factory, 90% of android issues are bad apps.
    Settings>Privacy>Factory data Reset
    Oct 21, 2013 | ASUS Transformer Tf300t Tablet
    ASUS MeMO Pad FHD 10.1" 16GB Android 4.2 Tablet - White Logo
    42 people viewed this question
    Top ASUS Tablets & eReaders Experts
    k24674
    Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
