Question about Brother PC-6000 Pacesetter
Brother pc-6000 bobbin winder does not turn - Brother PC-6000 Pacesetter
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
  • 16 Answers
SOURCE: Help me !!!!! Got a brother XL2230, bobbin winder broken
Hi, I have the same problem, use a car 'o' ring that should fix it, should cost about
Posted on Oct 01, 2010
  • 1788 Answers
SOURCE: My bobbin winder stopped working on my Brother
I think that I would call Brother at 1-877-276-8437 and ask them if this is a warranty issue. They may have a quick fix for you.
Posted on Oct 24, 2010
Testimonial: "Thank you. I am dropping it off at a nearby fabric store, and if they cant do anything, I will contact brother."
SOURCE: Brother CS80 ..... bobbin winder
check the power cord to see if it plugged in to the machine correctly
& if it is then something could be loose or broken inside, it needs to be serviced
Posted on Aug 03, 2011
  • 83 Answers
SOURCE: my bobbin winder will not work. I can hear the
Check the belt inside,might had came out or broken.Thank you.
Posted on Sep 16, 2011
Bobbon winder will not turn
the bobbin winder could be broken
Feb 14, 2016 | Brother Sewing Machines
Bobbin winder doesnt work
The bobbin winder tires on most of the new lower to medium end brother machines have a tendency to sort of melt. I honestly don't know what causes it, but basically the rubber ring that rides the handwheel and causes the bobbin winder to turn will liquify and drip off the bobbin winder and then re-solidify. It would be best to take your machine to a repair shop, to get the tire replaced and to have the old tire sludge cleaned out, though if you are adventurous, you could try it yourself. You can order a tire at the link I've provided, but most sewing machine repair shops can get you one as well.
Bobbin Winder Tire Babylock Brother X55238051
Jul 03, 2014 | Brother CS6000i Computerized Sewing...
Bobbin winder won't spin
i have the same problem ,its the o ring on the inside of the machine on bobbin winder , i purchased the o ring from brother for 27 pence i just need to know if its safe for me to open the machine without lots of springs popping out xx
Apr 07, 2014 | Brother XL-2230 Mechanical Sewing Machine
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Sep 09, 2013 | Brother CS-80
Bobbin winder shaft is not spinning
Try this (hope it helps!): http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx *Put '10percent' in the coupon code box and save 39c :)
Aug 19, 2012 | Brother CS-6000
Broken bobbin winder
For $29 at Hancock, Jo Ann's or Wal Mart you can get a thing called a Side Winder that will wind your bobbins without using the winder on your sewing machine. It has the additional advantage that you can wind while sewing. I use it even with machines that will wind bobbins.
Feb 25, 2012 | Brother XL-2230 Mechanical Sewing Machine
Bobbin winder does not wind evenly. how do i fix this problem
Slow down when you are winding the bobbin. You are going too fast and it will always be uneven when you do that.
Dec 28, 2010 | Brother CS-6000
Problems winding bobbin, is all of a sudden partway through fill, and the thread slipps below bobbin, and turns around metal post. Cannot get thread off post.
The reason is probably because the winder post is not perfectly vertical, check that and also make sure you put the thread round the pretension wheel before you wind a bobbin, getting to the inside to adjust it is very difficult.
Mar 07, 2010 | Brother PC-6000 Pacesetter
Bobbin winder doesn't turn, just makes whining sound.
If the spindle is not turning either the rubber is worn down one side or there is residue on the winder rubber or the winder itself is seized.
Nov 07, 2009 | Brother CS-6000
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
55 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
