Question about LeapFrog Tag Reading System
Leapreader not charging - LeapFrog Tag Reading System
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
How to add a leapreader book to a leapreader
you will need to download the LeapReader software from the LeapFrog web site
www.leapfrog.com
Install following the wizard
once installed on the righ there will be a link to download and sync the new software for your books
i hope that this helps?
Regards
May 06, 2014 | Toys
Leapreader won't turn off
Try pressing the on/off button to turn it off. I had a same problem. I depressed the on/off button for ~6 second or so and the device turned off. When I turned on again, the LeapReader no longer had a white light and was recognized by my computer.
Feb 01, 2014 | LeapFrog Toys
Leap reader won't turn on
I'm having the same problem with mine but on the faq on the leap frog connect i read that the product was defective and to contact customer support with it
Dec 26, 2013 | LeapFrog Toys
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
What is this vendosupport.com?? Why is money transacted to this site without my knowledge??
mony tarnsactions with out my knowledge in vendosupport.com i went to cansel the taransaction
May 04, 2011 | Computers & Internet
Not charging
Have try to use another similar charger to charge it to see if it will charge? If you have and yet it did not charge, it means the charger is not the problem.
The problem is the the charging port, the charging port of your phone is bad that is why it is not charging, all you need do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port and you will see that the phone will charge.
Take care.
May 20, 2010 | Nokia 1209 Cell Phone
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
LeapFrog Tag Reading System Logo
Top LeapFrog Toys Experts
thegtw
relojmesa
GI Consulting
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
