Question about JVC HD-61Z456 Television
SCREEN NOT VERY BRIGHT
MADE ALL ADJUSTMENTS,SCREEN IS VERY DIM.JUST GOT SET FROM BROTHER. COULD IT HAVE THE WRONG TYPE LAMP INSTALLED?
Headlight wiring help.
check for a loose dirty earth point for the lights. wire not earthed to a pint that is connected back to the battery.
Dec 06, 2014 | Nissan Cars & Trucks
Wd 73c9
You need to replace the TV projections lamp.
The lamp part number you need is 915B403001
Once you have replaced that lamp your TV will be bright once again.
Jul 29, 2013 | Televison & Video
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
Dec 16, 2012 | Sony KDL-32M3000 32 in. LCD Television
The tv is on then screen turns off and greenlight will blink understanby and then screen comes on again
If it has a lamp that has not been replaced in a long time it may be that---if it turns on slow and is somewhat dim that points to a lamp that is about to fail---set detects if lamp not full up or bright enough etc.
Oct 24, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
My tv's screem is little dark
Hello
If you set the lamp mode to LOW POWER, each time you turn ON the TV the lamp will start out at HIGH BRIGHT mode, but will switch to Low Power mode after a short period of time. You may notice a change in screen brightness when this happens. This is not a malfunction.
Just check whether you have selected this mode. Go to its user manual [P57]. All details are there about the lamp brightness settings. If it is not set to Low Power and still you get a dim picture, the lamp may be weak and has to be repaced. OK.
Nov 23, 2011 | Toshiba 65HM167 65" Projection Television
Dim screen, bright mouse pointer
Right click the battery icon on the right bottom of the screen in the task bar. The performance profile may be set to energy saver causing monitor to dim to save energy.
Sep 09, 2009 | Gateway Computers & Internet
Replaced bulb - no picture - blue dim light
Ur CRT need a rejuvenation,it a messy job.
It cost u the big screen repair shop about $300 dallors.
Sep 02, 2009 | Televison & Video
Mitsubishi wd-73727 have new lamp bulb;did not
Your Light Engine needs replaced. Usually around $600.00-$850.00
Jul 11, 2009 | Televison & Video
Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 24, 2009 | Acer Aspire 5735 Notebook
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before ....
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Mar 10, 2009 | HP Pavilion DV9720US Notebook
JVC HD-61Z456 Television Logo
29 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
