Question about Cyberhome CH-DVD 300 DVD Player
Need to restore default/factory settings
I need to restore the factory settings on my player. One of the settings in either the SETUP or PROGRAM option on the remote got changed and now the TV screen is blank. The setting was changed from the first/top opiton to the second and now I can't see any menus or anything in order to change the setting back. Is there a way to restore the factory/default settings on the player?
    President:
  • 814 Answers
Check out this website for troubleshooting and repair tips for these dvd players. Just plug in the the web address into your address bar. http://www.drx9000repair.netfirms.com/ This site has lot of information on these units. Hope this helps you with your problem.
Posted on May 18, 2009
How to hard reset my philips blue ray
BDP5506, HTS5506, BDP3306, HTS3306, BDP3506, HTS3506, BDP3106, HTS3106
Press the [Home] button on the remote. Then select [Setup]>[Advanced Setup]>[Restore defaults settings]>[Reset Network Setting]>[Yes]
BDP3406
Press the [Home] button on the remote. Then select [Setup]>[Advanced]>[Restore default settings]>[OK]
BDP7320, BDP7520, BDP5320
Press the [Home] button on the remote. The select [Settings]>[Factory Default]>[Network Settings]>[Yes]
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=BDP5506/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN
Feb 09, 2016 | Philips Televison & Video
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
How to take laptop back to factory settings
Depending on the brand and year it was made there may be a factory partition that will restore computer back to factory defaults, if not then a reinstallation of windows will be necessary, If factory partition is available just do a search o Google with your make and model # such as : How to restore an Acer Aspire 7425 to factory defaults using recovery partition
Mar 15, 2014 | IBM ThinkPad T40 2373 Notebook
HOW TO FACTORY RESTORE SAMSUNG R60PLUS laptop
hi
factory setting in bios
-set default
factory setting about program
- put the original CD or DVD (restore) in your CD drive
an restart the laptops
make sure that your boot sequence is CD drive
if it is not change it in bios setup
Jun 04, 2010 | Computers & Internet
Security code
I have a manual, try going into Setup mode then go to Custom Setup. In the drop down box, go to Default and by selecting this your player should default to factory default settings. The password then is set to factory default "8888". Under the Parental Control section of the Custom Setup Menu, you may try selecting bullet "8" also. Hope this helps.
Oct 25, 2008 | Protron PDV-288 7" LCD Portable DVD Player
How to restore factory settings for Coby 755 DVD Player
Ok I'm going to walk you through this...
Turn the DVD player on... give it a second to load up
Now Press Setup.. now navigate down 5 times Press Enter
Navigate down once Press Enter... Or it might just be a Press enter I'm reading from the manual. Click here for the Manual
That is the way to get to the factory default button in the setup.. If your having trouble doing that try using the manual to see where to go to get back to the NTSC settings
May 03, 2008 | Coby DVD-755 System
Screen reads FACTORY DIAG MODE
I had the "Factory Diag Mode" and was dismayed that I could not find a solution in any of my online searches. But I finally got it to work with only a minor side-effect, so I thought I'd share.
I originally tried the following from the "Live XM" mode:
Go settings, setup, restore defaults, restore setting only.
That didn't seem do anything for me. Then I tried the same thing from the "My Music" mode.
That fixed it!!!
The only thing that I noticed that I lost was my channel favorites (hardly a worry at all). All of my saved songs and playlists are still there!!!
Hopefully this will help a poor soul in need
Apr 06, 2008 | Samsung NeXus 25 MP3 Player
Curtis DVD 2100 DVD Player
page 1 in the set up menu will allow u to reset to the factory settings.
Oct 11, 2007 | Curtis DVD1045 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
221 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
