Bryan...Let me get this straight! You've been waiting since the DAY AFTER X-mas for a solution!? You's a Patient Man!
You have a Bad Command Module. In other words it is a $400-600 fix! I hope this was a Christmas Present. Because most manufactures (EVEN LG) have a ONE WHOLE year warranty!!! Gee Thanks! So you should call Home Depot, Because we all Know this is where you bought this Piec of Cr...! OOps sorry!
Yea, your main control board that works EVERYTHING is shot! You need either a new one of those! (but why did it fail? cuz it shorted!) Installed wrong! Not you! The factory. Or what I would INSIST! A Brand New Car! No wrong solution! New Machine Bryan!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Thanks Steven, for the response. I figured it out on my own though. You are correct. It was the main control board as I expected. It shorted out and blew a memory chip of some sort. You can actually see where the short occurred. It's all burned out looking, around the area. I've since, purchased a new washer, due to the cost of fixing this high priced, piece of crud for the last time.
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
SOURCE: I have a Maytag Model MAH8700aww washer
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
SOURCE: spin cycle won,t spin. starts then stops
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
