Question about OKI C Office Equipment & Supplies
My OKI C9650 forgot the admin password. how can I reset it
Hi. I have an OKI C9650. I used to access the admin menu with the login root and password from the last 6 digits of the MAC-address. but suddenly this doesn't work anymore! (although nobody changed it in the meantime). Now I can't access the admin menu with any passwords that I tried. I can enter maintenance mode with six zeros and statistics with four zeros, but I don't know where to reset this admin password. I even did an E E P ROM reset and HDD reset in MM, but this didn't change anything. Help please!
  • Juergen E
    Juergen E Jan 06, 2014
    I actually got help from OKI support: next to the LAN cable is a reset button. This clears all passwords.
How do i override admin password
Restart the PC, hold down F8 once you enter the Windows® Boot Menu choose
Safe Mode with Command Prompt, and now type in the following:
net user root /add
net localgroup Administrators root /add
net localgroup Users root /delete
The first command adds a new user called "root", the second command adds
that user to the Administrators group and the third command removes the
user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at mine Password Reset Disk Step-by-Step Guide.
Direct link: http://www.itknowledge24.com/
Nov 09, 2014 | Medion Computers & Internet
How to reset printer model OKI C562dn to default factory settings?
1.Click on Start and go to control panel
2. Go to programs and then uninstall a program.
3. Find and uninstall your printer software.
4. Restart your system and install your printer.
5. Restart your system.
6. Live Happily ever after !
Aug 04, 2014 | OKI C Office Equipment & Supplies
Forgot login password
Default User and Password on Everfocus is usually
Admin
Admin
Nevertheless, you should contact your local distributor, and after providing the product serial number, they can generate a reset user and password, that shall be used only once, and then, you must enter a new user/password combo.
Nov 16, 2012 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
I forgot the password for the 192.168.1.1 page what do i do
Please do the following.
1. If you have changed the default password you will have to reset router and the password will be set to the default password. To reset the router to factory default keep the reset button pressed for 15 seconds while the router is powered on the reset button is located on the back of the router inside a small hole which needs to be pressed using some pointed object like a pen or a pin.
NOTE** its importaint to note that if you reset the router to factory defaults you will lose all the configuration and you will have to reconfigure the router***
2. if you have not reset/ changed the password ever try using the following user name and password
username password
admin admin
system admin
root root
admin
System
root
Aug 18, 2011 | Gateway Wireless-B Router (wbr-100)
What is the default ip and user name, password for this model ????
The "IP address" is your DEFAULT GATEWAY so you can try 192.168.1.1 or you have to check it by going to START>RUN and type CMD in the box and then Enter (brings you to the COMMAND PROMPT type IPCONFIG and enter you will see your DEFAULT GATEWAY.
For the user name and password (you didnt mention the model #) so for all US ROBOTICS the User names are (unless you changed it) try "root" "Any" "support" "Admin" and Passwords are (unless you changed it) "12345" " Admin" "support" "password". If you did change it and cant remember you can always press the reset button on the back and restore it to the "Out-Of-The-Box" settings.
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Jan 06, 2011 | U.S. Robotics (USR5450) 802.11g/b Wireless...
I forgot my password on my computer
I know a windows password recovery tool called windows password buster. This software could help you recover the password.
Nov 28, 2009 | HP Computers & Internet
How can i change my linksis wifi password
access the GUI if it still on the default settings otherwise press the reset button at the back
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
Oki b6200 web-interface-login
As menttiones on Manual
The factory default of Administrator Name is “ADMIN” and Administrator Password is “xxxxxx” (the last six characters of the printer MAC address).
Alan
May 05, 2008 | OKI B6200 Laser Printer
How do I reset access password?
Thanks. I actually found out that it had never been configured - here is the standard factory access info: All Oki network printing devices support configuration changes via a standard web browser such as Internet Explorer or Netscape Navigator. When applying a configuration change to a device the user is prompted for a user name and password. The following details should be entered: User Name: root Password: last six digits of the MAC address* *You can find the MAC address on the network summary web page or by printing off a menu from the printer.
Nov 22, 2006 | Okilan 8100e Print Server
163 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
