I dont know but I guess its a hydraulic clutch operation and if so your problem is probably the slave cylinda leaking air or also quite probably the master cylinda short of fluid or again leaking air. system needs ot be blead to get it working if it happens again change the cylindas one at a time .
00-30-001 2000 ACCENT DMTL DIAGNOSIS: DTC CODES P1401, P1402 AND P1403 p1402 - dm-tl air pump motor is shorted or disconnected.
2000 model year accent is equipped with a new enhanced evaporative emission system. this new system is capable of measuring leaks as small as 0.020" diameter. the new system pressurizesthe evaporative emission system with a diagnostic module for tank leakage (dm-tl), while the previous model's system appliedengine vacuum through the purge valve to detect system leaks.
service information
vehicles that have the check engine light illuminated and have dtc p1401, p1402 and p1403 stored in the ecm should have their electrical systems diagnosed related to the appropriate dtc. these codes are not related in any way to an evaporative emission system leak. the conditions that set the diagnostic codes areas follows:
p1401 - dm-tl air pump motor current draw is higher or lower than expected (normal = 17-36 ma).
p1402 - dm-tl air pump motor is shorted or disconnected. p1403 - dm-tl changeover valve is shorted or disconnected
You will need to remove the entire chassis block as outlined in the manual. DM stands for digital board. It will be listed in the manual as PWB DM its sandwhiched in between other boards inside the chassis . Which is actually a metal box that will need to be disassembled then each board removed to get the DM . The DM is usually the bottom board. I dont have access to the WD65833 sertvice manual, but I am famillar with it. The DLPs are all simallar the entire Chassis block needs to be removed. Hope this helps if you need more info, let me know.
Yes on some sets are a bit differant depending on the model number there is still a DM board. The disassembly is a bit different and the service manual will describe how to take apart the TV set to get to the DM board. The repair is the same for the DM board. I am sorry but I do not have the the service manual but one can be downloaded here:
http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=WS55807
Good Luck
