The DVD player will not come on and 3 lights on the front panel are on. I checked the fuse it is good. I cannot find any burnt our items on the circuit boards. Any advice?
SOURCE: While rewinding, the DVD player just stopped working
Jeff/360Powner,
Tony/sonydvdvcr here,
I hope this helps. I have been unsuccessful in getting this to fix the tape player, but my sony dvd vcr slv360p unit now works and the dvd plays great. Still working on the tape part. Good Luck!
A few days ago when I was searching online for a solution to my own problem, I came across fixya. After posting the exact same problem as yourself, I began to remove the tape from the unit. Thinking I would have to cut the tape, I attempted to remove the video cassette without cutting it. I was successful. Here are the steps I took:
1. Remove the outer casing.
2. Remove the approx. 8" bar (2 screws) across the VHS entry area. (You can do with or without removing face of player. Be careful if done without)
3. Remove 4 or 5 screws in base holding the entire video assembly to floor.
4. Next, is the tricky part. First determine if the tape is one you want to salvage. If so, slide the tape film out of the roller areas where it is strewd out while it was being rewound so it is free, otherwise cut it. You will then have to pry the VHS up in the front through the entry door and push from the rear. Might have to try a few times, walk away, then try some more. But it will come free. Tension can be eased by simultaneously prying on the sidetabs holding the cassette in the player. Careful not to break tabs.
5. Once tape is free, you may be done, but I kept on in uncertainty.
6. Next I removed the entire video tape assembly by raising it off the tall pointed posts enough to clear them but not too much where you put excessive strain on the several computer bands that are attached.(I did not disconnect those, just be careful)
7. Raise the assembly off of the floor and then replace. There is a slim narrow plug style deal that is fixed to the floor that the assembly rests in. I believe this is significant to allow the player to reset.
8. Check power now before you replace everything. You should see the tape assembly physically reset and disengage from the rewind position.
9. Replace assembly and bar and face accordingly.
I hope this helps. I have been unsuccessful in getting this to fix the tape player, but my unit now works and the dvd plays great. Still working on the tape part. Good Luck!
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
SOURCE: unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
SOURCE: What is a good burn program for this DVD player?
The Mac and software is not the problem. The Sony DVD player is the culprit. Sony has some proprietary bullsh.t lock hardwired into their system to not play burned discs.
Go on e-bay and look for region free DVD players, which will play any disc like a champ. Sony is a good brand, but they are picky about playing certain discs. Re-gift this thing to someone during Christmas or sell it.
SOURCE: I have a Sony BDP300
HI...
Unplug the AC for an hour , Try again.
If still **** , see if it's under warranty
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
