How do you open the CD rom drawer on a Toshiba L75D-A7283?
  • 221 Answers
SOURCE: My Cd-Rom/DVD-rom don't work. It
According to the Toshiba website, the scsi cd-rom/dvd-rom does not require a driver to operate, but the driver for the scsi controller card it plugs into may need to be reinstalled or updated. Visit the following link, and go to the section labeled scsi cdrom/dvdrom. At the bottom of this section there are two links to websites where you may be able to find the drivers for your scsi controller card.
http://sdd.toshiba.com/main.aspx?Path=8100000000220000000100006598000000E7/810000000C58000000010000659C00002C36
Posted on Apr 09, 2008
SOURCE: toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
Posted on Oct 07, 2008
SOURCE: cd rom drawer keeps opening
There is something that keeps the drive from coming out. You would have to find the nearest computer technician to you and it will be quickly fixed for you.
Posted on Nov 10, 2008
vincebeach
  • 37 Answers
SOURCE: dvd cd rom not reading anything on my Dell computer
Having to use a paper clip instead of the eject button working could indicate a power source problem. Not reading anything on the drive could be either power source, connection cable or motherboard. I would start by removing the drive and checking all connections. You did not state if this is a laptop or desktop. If it is a desktop, there should be several unused power connections.If you do not have the ability to check the used connection, just switch to a different one.Also check the connection cable to the motherboard and if possible change or replace that. If all this fails, I would assume from a distance that the DVD drive is defective and try to replace it.
Posted on Dec 17, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Internal CD ROM will Not Open
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Posted on Jan 01, 2009
I have no bottom on my cd drawer on my Toshiba pc ,how can I open it ?
BUTTON, BUTTON!!!
Weird! Al CD/DVD players on laptops have a button to open the device.!!!
Now you can open an optical drive by right cliccking on CD/DVD Rom in My Computer and select EXPULSE... BUT i INSIST, YOU must have a physical way to open your drive
May 31, 2015 | Toshiba Computers & Internet
Toshiba Satellite L75D-A7383 is taking a long time adding attachments to Yahoo?
Hello Brian Smith,
Please open your internet explore and go to internet option and clear browsing data and reset your internet explore.
thanks,
Mar 05, 2014 | Computers & Internet
My toshiba dvd-rom is not reading any cd
Cd's and dvd's use different lasers. Most likely cd laser isbad. this is a common problem. For ensure please
Click on the link bellow link
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
And clink on RUN NOW from right side box
It will fix your problem.
It could be a problem with the lens, you should try cleaning the lens, it'salready gone bad there is no harm in trying. If you take a little risk cansolve.Follow the instruction: Don't panic it's very simply.
  1. When running your pc, open the drawer.>
  2. Clean the optical lance
  3. Now you can fit to your pcIf you using pc desktop
  4. If it does the same problem, please change the cd/dvd r/w because the lance has defected.
  5. you should purchase.http://en.kioskea.net/guide/optical-drives-45/toshiba/
  6. How to replace cd/dvd r/w e.g. follow bellow the link=http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&dlc=&cc=us&lang=&product=242024
  7. Some time you should change the fittings follow the link.http://www.insidemylaptop.com/replacing-optical-drive-toshiba-satellite-a50-a55/
  8. Follow the disassemble guide http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
  9. To enlarge dubble click on pic.
Hope this helps
Jan 07, 2011 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Cd rom drawer on dell laptop won't open
hello, have you tried going into "My Computer" then right clicking on cd drive and click "Eject"? if not, try that.
if you have then take a thin paper clip open up one side of it so its straight.
After you have paper clip straighten up look carefully around the cd rom's eject button and you will notice a tiny hole.
Take the paper clip and keeping it straight slowly and gently insert in the hole and soon you will feel little resistance push it a little bit more and that should eject your CD rom.
if it opens up leave the cd rom open and reboot your laptop once and see if your drive now work normally and ejects the way it should?
hope this helps, post back if you have issues.
Kind regards,
Amar Sondhi
Jan 22, 2010 | Dell Inspiron™ 600M PC Notebook
The CD drawer doesn't open...I push the button and it sounds like it's going to pop the lil drawer open...nothing happens. Help pls...
take a paper clip and streighten it out in a long wire - you should see a hole in front of the cd rom by the drive bay press it in the hole and push the drive open
here is a video
http://www.youtube.com/watch?v=kscn5_XG2oE
Dec 27, 2009 | Compaq (120192-B21) CD-ROM Drive
Cd burner drawers wont open or close
sounds like a bad cd rom. as cheap as they are the best option is to replace.
Mar 19, 2009 | Dell Dimension 2400 PC Desktop
Cannot open cd drawer
If it will not open by itself, open up a small paperclip and push it into the little hole on the front of the cd rom. This will release the latch, and allow the drawer to open
Mar 16, 2009 | Gateway Computers & Internet
Dec 31, 2008 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
Toshiba 1625CDT CD-ROM
How old is the cd-rom? Dust, and years of use can cause the laser to wear out or misalign.Try blowing hard inside with the drawer open (silly, isn't it? but I am not joking. my place is dust prone and I have to do that all the time). But if it is as old as the operating system, maybe it is time to get a new drive.
Oct 14, 2008 | Toshiba (K000680310) for Satellite...
Model A40 cd player
This was the same problem faced by me.Check the mother board and if you are still on warranty go to the manufacturer.
Aug 18, 2007 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Computers & Internet Logo
David Payne
David Payne
