Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
I have a robinair cool tech 700 not recovering
I went to use my machine yesterday and I hooked it up and hit recover. Waited about 10 minutes and nothing happened only an occasional clicking noise. Any ideas?
    President:
  • 180 Answers
You Need to replace your unit compressor.Because may be you did not change spin-on filter after recovering 150 LBS of refrigerant.
Posted on May 19, 2009
Robinair model 34288 will not stop recovering
what is the pressure reading on your guages? if it is below 0 if so the vacuum pump should kick on. if the vacuum pump keeps turning on and off check the software version on the machine if it is not 3.09 or 3.11 the software needs updated contact your local robinair service center. if it is not the software then the recovery solenoid may be sticking closed and will need replaced.
Jul 07, 2012 | Robinair Cool Tech 34700Z Recovery,...
NEED WIRING DIAGRAM FOR ROBIN AIR 34700Z MINE WILL NOT RECOVER FOUND YELLOW WIRE MARKED #67 WAS UNPLUGED. WHERE DOES IT GO.
You can try to get it only from any Robinair service center, No one can post any Robinair service manual at web site because of copyright! If you wish you may check my other solutions which i've post earlier for the same problem.
Yellow wire marked with 67 is a ground wire & you can hook-up anywhere in machine body
Nov 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34788 machine and when I am recovering a system for service the recover feature no longer completes down to the oil drain. Its like it gets stuck on recover.... and by that I mean it...
It's sound like problem with oil drain solenoid or harness. please check harness of oil drain solenoid. If harness is ok & connected with relay board then you need to replace oil drain solenoid.
Oct 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
Machine says pressure exist unable to vacuum system down
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
Sep 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
Over charging won't recover scale don't work
It is not clear which model of robinair machine you have! However your machine need to re-calibrate the scale.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a a modle 34788 robinair cooltech my day shift messed it up is there a way to fix my problim? it wont recover at all. all other functions work (with the lines off i can get it to vacumme)when i hook...
Please check 1# The compressor suction line with a vacuum gauge & make sure it has 13" HG of suction while you active recover. if not then you need to replace the compressor. 2# Check spin-on filter O rings are fixed properly it may missing or lose, also check filter capacity (amount of refrigerant you have been recover sinc last filter change.every 68KG or 150LBS of recovery you must change spin-on filter)
Jun 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
How to charge
Which model of Robinair machine you are using ? If it's 34700Z then follow as: After Recover & Vacuum, Press "CHARGE" button on contro panel & add the amoun you want to charge then press ''YES" button.
Jun 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont recover
Please Check the following:1# Press recover & fix a vacuum gauge on your machin Compressor suction port & monito the gauge is going up to13"HG suction,if not then you may need to replace the compressor.2# Check spin on-filter weight(total amount of refrigerant you have been recover since last filter changr,Max.filter Capacity is 68KG/150LBS) if it's more then max.cap. replace the spin on-filter.3# Check low side clearing sensor (Vacuum sensor) for proper operation.4# Also you can try to reset (clockwise & counter clockwise) automatic expension valve for any block of refrigerent flow.
May 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
1,140 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
