Question about Refrigerators
F32 error code on my Gorenje Wa142 washing machine
Washing machine stopped and displayed F32 error
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
  • 1294 Answers
SOURCE: Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Posted on Nov 30, 2007
Master_Tech
  • 770 Answers
SOURCE: 5L error code
I will pull the book and get back to you today
Posted on Jan 27, 2008
SOURCE: Error code F32 for fisher
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
  • 127 Answers
SOURCE: gorenje washing machine on display shows F31. what
it means"The connection to the tacho generator is open or short-circuited". that means the motor is not turning. 99% it is the brushes (20 eu) and it wil work again.
marko
Posted on Aug 13, 2009
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
Machine displaying f32 error code where is the pressure switch
water pressure switch is usually located in the panel section? its a small round pc of plastic with a hose going into it, and usually has 2 or 3 prongs.
Sep 27, 2014 | Washing Machines
What is a F32 error code on a maytag 3000 series
Error Code F3 E2 is a temp system error. This error is displayed if the water temperature sensor value is out of range (23°F to 217°F [-5°C to 103°C]). Correct ohm reading should be 500-100K ?.
Jan 28, 2012 | Maytag Washing Machines
WFW9200SQA12 f32 error
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
  • Pressure switch failure
  • Check the Pressure Switch wiring harness for continuity.
  • Check the Pressure Switch for correct operation with a Digital volt/ohm meter.
  • To manually check the function of the Pressure Switch, remove hose from switch and apply air to switch. Audible clicks will be heard from the switch.
Jan 15, 2011 | Whirlpool GHW9400 Front Load Washer
Kenmore Elite Oasis HE Model #110.27087604. My washer had an error code "ld". I removed the hoses from the pump and discovered loose change in the pump that was probably jamming the impeller. I removed...
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Whirlpool Duet has just come up with F32 error on display. Any ideas please?
I checked my code book and there is no f32. you should have a code tech sheet. this would be located on the bottom panel insid the washer. Check to see if they have a f 32 code.
Nov 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine error
Hi! stachill
Sound like a power problem, or a connector problem between the three different IC control cards.
InMrFixIt
Aug 24, 2008 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
312 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
