Question about Dishwashers
FRIGIDAIRE FFBD2406NW LOCK LIGHT IS ON - Dishwashers
Why does my Frigidaire 2406 Series Model #FFBD2406NW not drain all the water out. Water is left in the to within one foot of pump (can't see that last foot). the connection to the pump.
From its manual, page 14. Dishwasher Does Not Drain
Properly
•If unit is hooked up to a food waste disposer, make
sure the disposer is empty.
•Check to see if the knockout plug has been removed
from inside the food waste disposer inlet.
•Check to see if drain hose is kinked.
•Make sure cycle is complete, not in a pause.
https://www.youtube.com/watch?v=diLwy0HZdd4
Above link is a Frigidaire Diagnostic link
Frigidaire Dishwasher Water not Draining Troubleshooting and Repair
Note some of the uTube videos beside these links. Some even cover pump replacement. Others offer generic advice. If the links above do no fix the problem, you at least have eliminated some potential causes and can go from there.
Aug 13, 2017 | Frigidaire Washing Machines
Frigidaire gallery washing machine door lock light doesn't come on
normally the door catch on washing machines have a switch attached to it ,if the door is not closed properly then the switch is not operated ,stopping the door lock light coming on
try slamming the door shut or check door catch for damage or hold /push and (hold )door shut to see if lock light comes on, if it does then the problem is door catch, adjustment or replacement only suggestions .good luck
Sep 27, 2016 | Frigidaire Washing Machines
Dishwasher wont turn on when I press start and... the "3 second" lock light is constantly on??
Child Lock Controls
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock the
dishwasher controls by pressing and releasing the RINSE
ONLY pad (some models) or the NO HEAT DRY pad (some
models) for 3 seconds while the door is latched. An
indicator light on the lock graphic pad will illuminate when
the controls are locked and no new selections can be made
until the lock is released. To unlock the controls, press the
same pad, RINSE ONLY or NO HEAT DRY, again for 2
seoncds until the indicator light goes out.
Hope this helps?
Mar 31, 2016 | Frigidaire FFBD2406NW Built-In Dishwasher...
Just installed a new dishwasher. It will not fill with water. Power on, water on, overfill valve moves free. Water does not go in unit @ all. I can hear pump run.
Hello Tony, I appreciate your inquiry!
I see that your Frigidaire dishwasher is not filling with water and it has just recently been installed. Is your door shut tightly? Also, are there error codes or lights being displayed on the control panel? I would suggest reading back through your installation guide to make sure all the steps were correct. If you continue to have issues with your dishwasher I would recommend reaching out to your manufacturer for proper warranty procedures. -Matt
May 29, 2015 | Frigidaire FFBD2406NW 24" Built In...
Where is the ground wire on this model?
Thanks for your post, friend!
I see you would like to locate the ground wire on your Frigidaire dishwasher. I did locate the wiring diagram along with a parts breakdown for your model, FFBD2406NW. I hope this is helpful. -Matt
Frigidaire Manual Search Results
Sep 24, 2014 | Frigidaire Dishwashers
The panel of my frigidaire dishwasher has a dummy light signifying a lock. it will not respond to any other button
to lock this unit out you have to hold the lock button down for a few seconds until lock light comes on. lock button could also be a combination button with start button or some other button. hope this helps!
Aug 29, 2009 | Frigidaire Dishwashers
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Lock light is on
The lock only locks the buttons (childproof), hold it 3 seconds and it will go out.
Jan 18, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
