Question about Toys R Us Tabeo
Reset button where is reset button
    New Friend:
Setting - personal you will the option for backup & reset.
Posted on Dec 26, 2013
How do I factory or hard reset my digiland model No. Dl8006 tablet
hard reset
hold down the power button and the volume down button at the same time till the chinese writing comes on
then go down with the volume down button to the 6 menu = 3rd from bottom press the power button to ok it
then it will reset
if its in english do the first bit hold down power button and volume down button at the same time till the android man with writing comes on
go down to wipe data withe the volume down button highlight that press the power button to ok it
then go down to yes with the volume down button highlight yes press power button to ok it then it will reset
then if it goes back to the writing go to reboot highlight that press power button to ok it
factory reset settings go down to back up and reset click on
go to reset
then it will reset
Mar 17, 2018 | Tablets & eReaders
HOW TO RE-SET PRESTIGE ELITE 8Q ANDROID TABLET
hard reset
turn off tablet
press and hold power button and down volume button at the same time release the button when you see visual land then hold the volume up button
you will see the android man with writing go down with the volume down button to wipe data highlight wipe data press power button to ok it
then the writing will come back on highlight reboot press power button to ok it
the tablet will reset
Factory reset
go to setting click settings
go down to back up/factory reset click on that
then press reset everything
Mar 14, 2018 | Tablets & eReaders
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
Jan 04, 2016 | Tablets & eReaders
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Aug 18, 2012 | Coby kyros Tablets & eReaders
I keep getting an error message everytime i turn it on and when i try to look at my pictures in my gallery.. it says something like andriod.proces..media isnt working and also it will knock me off the...
You did a soft reset, try master reset: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
*******This procedure will delete all items (file's) and entries on the MID7015******
Aug 27, 2011 | Coby Kyros 716829701508 Tablet PC
How can i reset my coby tablet
Aug 20, 2011 | Coby Kyros 716829701508 Tablet PC
How to unlock it if you forget the password?
This is for MID7015
Jul 07, 2011 | Coby Kyros 716829701508 Tablet PC
Where is the reset button in this product? The first thing the manual tells us to do is to put batteries & reset the machine by pressing the ''reset'' button. I have studied the buttons some 10 times but...
On the back of the viewsonic tablet pc or at least on the V1100 the is a small pinhole type openining. Here you may need something as small as a needle to depress the button. It is located 3/4ths of the way down on the back of the pc.
Apr 12, 2009 | ViewSonic ViewPad 1000 Tablet PC
Toys R Us Tabeo Logo
52 people viewed this question
Top Toys R Us Tablets & eReaders Experts
Bill Boyd
andrewcahoon
micky dee
Are you a Toys R Us Tablet and eReader Expert? Answer questions, earn points and help others
