Question about Hannspree 10.1-INCH QUAD CORE TABLET PC T7 SERIES WITH IPS 1280X800 10 POINTS TOUCH BLUETOOTH AND 16GB MEMORY ANDROID JELLY BEAN METALLIC WHITE COLOR
Will not power on ,just gives logo.called helpline ,did resets
Has been charging for two days
  • Corinna Roberts Jul 04, 2015
    How do you reset if your tablet doesn't have the volume buttons on the side of it??? Mine is just showing the logo & then freezing but my volume buttons are on the screen on the bottom toolbar!
Press and hold VolumeUp(+) button and Power button at the same time for 5 seconds, and release both buttons to enter system recovery utility.
There are 6 options on Android system recovery utility.
  1. Reboot System Now
    Exit the system recovery utility and reboot.
  2. Apply Internal update.zip
    Run the Software update. The update Software (update.zip) must be stored in root of internal storage /sdcard.
  3. Apply External SDcard update.zip
    Run the Software update. The update Software (update.zip) must be stored in root of external SD Card.
  4. Wipe Data/Factory Reset
    Run Factory Data Reset. All settings will be restored to factory default settings and user will be required to do the initial setting.
    (All installed applications and user personal data will be erased (created mail accounts, contacts...etc.) from device. Data saved in both external and internal storage like photos, music files and others will not be erased.) Make sure to back up files.
  5. Wipe Cache Partition
    Clear device caches.
  6. Calibrate Touch panel
    Run touch panel calibration automatically. Please be aware of the wrong operation or misuse might cause touch panel
    abnormal. Please follow the instruction shown during the process.
you can choose no.4 option
Posted on Jun 14, 2014
    Sergeant:
  • 246 Answers
Try to reset default factory
Posted on Dec 26, 2013
  • Cyndi Adkins
    Cyndi Adkins Jun 09, 2014
    How can you reset if it doesn't come on?
  • fury fury rior
    fury fury rior Jun 14, 2014
    try this Reset button It is a physical button on the bottom right corner of rear case. It helps to restart the system compulsively when system halted.
IPad air suddenly went black, except for a dim rotating circle of dots in the center of the screen. It is completely unresponsive. Know any fix we could do?
Put it on to charge. Press and hold the On button and the Home button until the white Apple logo appears and then let go. This is called a Soft Reset.
Dec 11, 2016 | Tablets & eReaders
Good day guys, please help its very urgent. my moms friend downloaded a game and now the phone doesnt charge or switch on even with new battery.
Try pressing and holding the power button to see if you get access to power-on/power-off options, or immediately pressing and holding the power-off button when you turn it on. You are looking for the option to start up in Safe Mode. If you can get into Safe Mode, then you should be able to delete the offending game.
Apr 23, 2016 | Samsung Tablets & eReaders
My kindle is frozen and will not respond to any commands. It is fully charged.
Slide the power button and hold it there for approx 20 seconds. Let go - this should reset the unit and it should come on again within a minute or two. If it doesn't - phone Amazon. Their helpline is very good.
Aug 08, 2015 | Amazon Kindle Paperwhite
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
Mar 31, 2014 | Hannspree SN10T1 101 Tablet
Wantturn on
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 12, 2014 | Kocaso M760P 1.2GHz 4GB 7" Capacitive...
Reset klu lt7035 f
get into emergency recovery mode, most Androids use the up/down volume at the same time while turning it on. release the power button when it displays the first logo but keep the volume buttons down till you see the Android logo. volume down button to see the first menu read the screen follow the prompts for factory reset Plus wipe data. ****** warning: make sure your battery is fully charged before doing this *********
Dec 28, 2013 | Tablets & eReaders
My son put a password in the tablet n forgot it. I need to know how can I do the factory reset on it
By doing a factory reset. 1.) Charge it all the way 2.) Power it off if its on 3.) Hold the up and down volume buttons at the same time 4.) While doing #3 press and hold till you see the logo then release only the power button. 5.) You should see an android logo, volume down for first menu. 6.) Follow instructions for factory reset wipe all user data. **** you must have min 50% battery ***** just charge it all the way.
Dec 28, 2013 | Visual Land Connect 9" Android Tablet...
Pattern unlock
About the only thing you can do is a factory reset of the device. As a security feature, however, you will lose any data stored on the tablet when everything resets to factory defaults.
To reset the device, press the (POWER) and the (VOLUME +) buttons together and hold them down for approximately 10 seconds, when you see the android logo, release the buttons and follow the on screen menus.
If this isn't something you are comfortable doing, give me a call during business hours tomorrow.
Hope this helps...
Mikeal
Dec 19, 2013 | ViewSonic G Tablet 101 Multitouch Android...
My binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to service@shriro.com.au India customer service number +91 7503011385 or email to assist@binatonetelecom.in
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
Oct 21, 2011 | Tablets & eReaders
Hi guys, during upgrade I did something wrong. So, now I have on screen of my tab logos of pc and mobile with triangle in between. No charging, non responding, no hard reset available. Please, help...
Have you tried the hard reset? Try these instructions for a hard reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
Mar 02, 2011 | Samsung Galaxy Tab Tablet PC
Hannspree 10.1-INCH QUAD CORE TABLET PC T7 SERIES WITH IPS 1280X800 10 POINTS TOUCH BLUETOOTH AND 16GB MEMORY ANDROID JELLY BEAN METALLIC WHITE COLOR Logo
450 people viewed this question
Top Hannspree Tablets & eReaders Experts
David Payne
David Payne
yobo007
yobo007
ka4iup
ka4iup
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
