Question about As Seen On TV TV Listener J3 Wireless Headset
Transmitter lights do not illuminate
Transmitter lights on the front will not illuminate. switched power sources to no avail. flipped on/off switch several times and still nothing. Purchased unit on ebay thru Harris communications INC. Where or how do I return for replacement?
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
Feb 19, 2017 | Cars & Trucks
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
How do i ? ive a 2012 chery j11 and iam unable to find any info on how to program the keyless remote for it please help regards Dan
The Service Manual says this...
Remote Keyless Entry (RKE) Inoperative
No Response From Remote Keyless Entry (RKE) Transmitter
1. CHECK BATTERY
• Check battery of the RKE transmitter.
Is the battery voltage of the RKE transmitter normal?
Yes >> Go to the next step.
No >> This concern has been caused by the transmitter battery.
Go to step 4.
2. CHECK THE IGNITION LOCK CYLINDER CONDITION
• Check the ignition lock cylinder for proper operation.
Is the check result normal?
No >> Repair or replace the ignition lock cylinder key switch.
3. PERFORM THE RKE TRANSMITTER MATCH PROCEDURE
• Close all the doors.
• Insert the ignition key into the ignition switch which has lost synchronization in LOCK position.
• Press any button on the RKE transmitter within 5 seconds.
• Pull the ignition key out of the ignition switch.
• Try to operate the RKE transmitter.
Does the RKE transmitter operate properly?
Yes >> Erase all codes before returning the vehicle to the customer.
No >> Go to the next step.
4. PERFORM THE RKE TRANSMITTER MATCH WITH THE X-431
• Replace the RKE transmitter.
• Connect the X-431 scan tool to the Data Link Connector (DLC), press the POWER key to start the X-431 (use the most current software available).
• Turn ignition switch on.
? Enter the Diagnostic Program.
? Select Chery main program.
? Select diagnostic version.
? Enter download program.
? Select T11 series, and then select ISU.
? Select Remoter Match.
• Press the lock button on the RKE transmitter for less than 2 seconds.
• Pull out the ignition switch.
The concern was caused by the RKE transmitter.
No >> Replace the FBCM (See FBCM Removal & Installation in Section 15 Body & Accessories).
Refer to the RKE transmitter match procedure with X-431 as the description.
Perform match between the RKE transmitter and FBCM with X-431.
Best wishes from another Chery J11 owner.
You can download the entire service manual from the link below.
Kevin Mullen
Perth WA
Chery Tiggo 2009 Service Manual Page 1699
Nov 18, 2014 | Refrigerators
The lock button on my key fobs will not lock the doors on 06 honda crv
CHeck to see if it is the right battery - Should be a CR1616 - previous year models, had a different battery.
Does the light come on on the key fob, when you push the button?
You may have to reprogram the remote - check the owners manual for instructions - if you can't find them...
Programming the Transmitter
NOTES:
• The system accepts up to three transmitters. The
transmitter codes are stored in a stacking-type
memory. If a fourth transmitter code is programmed,
the code for the first transmitter is erased.
• Entering the programming mode cancels all learned
transmitter codes, so none of the previously
programmed transmitters will work. You must
reprogram all of the transmitters once you are in the
programming mode.
• You must complete each step within 4 seconds of
the previous step to keep the system from exiting the
programming mode. Program the transmitters within
10 seconds.
1. Turn the ignition switch to ON (II).
2. Press the "Lock" or "Unlock" button on one of the
transmitters. (An unprogrammed transmitter can be
used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times using the
same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the "Lock" or "Unlock" button on the same
transmitter. Make sure the power door locks cycle
to confirm that the system is in programming mode.
7. Within 10 seconds, press the "Lock" or "Unlock"
button on each transmitter. Make sure the power
door locks cycle after you press each transmitter
button to confirm that the system accepted the transmitter's code.
8. Turn the ignition switch to LOCK (0) to exit programming mode.
IF so, and more likely, the fuse on the car side of the remote, is probably gone.
Apr 25, 2012 | 2006 Honda CR-V
I have a 00 petrol ford focus but the fob key does not work anymore. I saw a programming explanation for a 02 diesel focus and I am wondering if there is such a solution for my car? Thank you.
OBTAIN ALL REMOTE TRANSMITTER. TRY THIS PROCEDURE.FASTEN SEAT BELTS AND CLOSE ALL DOORS.TURN IGNITION SWITCH FROM OFF TO ON 4 TIMES WITHIN 6 SECONDS.SWITCH IGNITION OFF,ACOUSTIC SIGNAL WILL SOUND AND SYSTEM WARNING LAMP WILL ILLUMINATE INDICATES CORRECT PROGRAMMING.WITH IN 10 SECONDS.PRESS AND HOLD ANY REMOTE TRANSMITTER BUTTON. WAIT FOR ACOUSTIC SIGNAL AND SYSTEM WARNING LAMP TO FLASH INDICATES CORRECT PROGRAMMING. TO PROGRAM ANOTHER REMOTE TRANSMITTER, REPEAT ABOVE PROCEDURE WITHIN 10 SECONDS.TO EXIT PROGRAMMING MODE,TURN IGNITION SWITCH TO CRANK OR WAIT 10 SECONDS. IF THIS PROCEDURE FAILS YOUR IGNITION KEY WORN OR IGNITION SWITCH RING COIL BAD.
Mar 15, 2011 | Ford Focus Cars & Trucks
Do I need to reprogram all of the key fobs for my 05 chevy silverado 3500 or do I just need to program the new one? If so How is it done?
All key fabs need to be programmed at one time.
Method 1 - No Tools Required, Program All Transmitters
Important: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the door unlock switch.
  4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to 4 transmitters.
  8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
  9. Operate the transmitter functions in order to verify correct system operation.
Nov 25, 2010 | Chevrolet 3500 Cars & Trucks
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
Intermittent power??
Larry, The green power automatically detects the source when you plug it in. If the volume is too low or non-existent (under-modulation) the green light automatically switches off in 10 minutes after you've plugged the transmitter into the source. At least that's what the manual says. It should work with a laptop.
Dec 25, 2006 | Sennheiser RS130 Headset
As Seen On TV TV Listener J3 Wireless Headset Logo
18 people viewed this question
Top As Seen On TV Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an As Seen On TV Radio Communication Expert? Answer questions, earn points and help others
