How to repace worn drive belt for panasonic cassette player model RX-2700
Needs belt route diagram and easy way to replace
PyroPCMan
  • 405 Answers
SOURCE: Drive Belt
1ab6618.jpg Fig. 29: Drive belt routing-1996-98 4.3L, 5.0L and 5.7L engines
Hope this helps
Posted on Jul 02, 2008
  • 718 Answers
SOURCE: THERE IS NOT PROBLEM.
Go to;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
and enter your model number, click Search and the download to click on.
Posted on Apr 13, 2009
old marine
  • 2152 Answers
SOURCE: need routing diagram for 2000 lincoln town car serpentine belt
There's a diagram at this link.
Posted on May 11, 2009
  • 1757 Answers
SOURCE: Need serpentine belt routing diagram for 1994 Dodge grand caravan
3.3L?
Looking at the engine from front (right side of the Van): Stating at the Top, Going Left to Right and Clockwise:
Over the Alternator
To under the Idle Pulley,
To Over the AC Compressor.
To the Left Side of the Water Pump.
To the Right side and Under the Crankshaft Pulley
To the Right side and Over and Down the Tensioner
To Under the Power Steering Pump
And Back up-to the Left side of the Alternator.
Advise when puting it on:
Put the Belt around everything else accept for the Alternator. After it is around all the rest of the Pulleys - Pull the belt up - tight from the Power steering Pump and the Idle Pulley to form a loop, holding the Belt close to the Altenator Pulley.
Using the 15mm wrench or belt tensioner bar - rotate the Tensioner Pulley towards the front of the Van and then place the belt over the Alternator.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
Posted on Jan 22, 2010
  • 244 Answers
SOURCE: need a serpentine belt routing diagram for 2001
it doesn't show you under the hood near the hood latch ,newer vehicle it should. check this first.
Posted on Apr 23, 2010
It loads tape but reels wont turn
Guess it's a mechanical cassette player and pulleys or drive belts are worn out and loose. You should look for available part to repace it or them
Aug 09, 2015 | Audio Players & Recorders
I need info on how to route the drive belts on a Panasonic RX-FS 460 cassette player/recorder.
I realize this question was asked a long time ago, but I'll post a photo now anyway in case someone else has this same question. The drive in this machine and also in the RX-FT560 has two belts. The long one makes the capstans go around, and the short one makes the take up reals move. In the photo, you can see the short belt, and I have drawn a not too straight line where the long one goes. It goes under the big wheels that drive the capstan spindles and around the motor pulley. I hope this helps someone.
Feb 24, 2014 | Panasonic Audio Players & Recorders
Timing chain making noise after water pump replasement
Basically its said,that when water pump is replaced,its also advisable to replace timing chain.The timing chain is either worn out or while replacing water pump,the timing chain got misaligned.It has to be inspected.Most probably,it needs to be replaced.
Below is the master help link provided to go through belt routing diagram:---Timing belt,timing chain, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Feb 27, 2012 | 2002 Dodge Stratus
Toyota yaris timing belt diagram 2007 model
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Feb 20, 2012 | 2007 Toyota Yaris
I replaced the power steering pump on mt 2000 montana and it keeps throwing the belt off..why?
pulley on which belt is routed is worn out or belt is not original.But original parts and see if that makes a difference.Or the belt is not getting routed properly.
Feb 15, 2012 | 1999 Pontiac Montana
Cassettes tapes not moving in my Panasonic RX-ED77
If you can her the motor turning, there is a good chance that the belt(s) have broken and need to be replaced. If you hear nothing, then there could be a control issue. I'm leaning toward the belts though. Figure on $5-$15 for the belts,
Dan
Mar 18, 2009 | Panasonic SA-XR55 Receiver
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
1994 Corvette Cassette/Radio?Replace cassette "drive belt"??
Donne Trav, you can take that belt to an electronics shop (your neighborhood shop is best). They will most likely have replacement belts. They will also have a tool that measures the belt so you know which size to get. I used to fix T.V.'s and VCR's. Its the best method when you cannot source an original belt. As far as the diagram, I would need a model # of the radio to even start a search for such a thing.
May 16, 2008 | 1994 Chevrolet Corvette
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
 Grubhead
Grubhead
