Question about Gateway Computers & Internet
Upgrading a Graphics card in a Gateway FX 6840-03e
My comp.wont start, I get 1 long and 2 short beeps. I have reset my memory sticks and it was sugg. to replace the video card. What or where can I find compatible components that will fit and plug and play? I dont want to have to replace anything else at this time( Motherboard,Power supply ect,ect.) Thanks in Advance...Joe
  • 55 Answers
SOURCE: Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Posted on Nov 30, 2008
micromend
  • 748 Answers
SOURCE: Gateway GT5228 not loading Video
Checked memory?
Posted on Mar 27, 2009
brownleopard
  • 15 Answers
SOURCE: Need to upgrade video graphics card for HP a305w.
That computer has 3 PCI slots. (I got the specs here: http://www4.dealtime.com/xPF-HP-Compaq-A305W-Intel-Celeron-2-7GHz-256MB-DDR-40GB-HDD-CD-RW-10-100Mbps-LAN-Support-Wind ).
The 6200 is compatible, just make sure it's the PCI version and not PCI-E.
Posted on Jul 19, 2009
SOURCE: Upgrading my Acer Aspire M1641 Desktop graphics card
The motherboard will support any PCI Express x16 or PCI Express 2.0 x16 video cards. Your main concern should be with the power supply since it is either a 300w or 250w.
Here is a pretty good choice for your price range:
http://usa.asus.com/products.aspx?l1=2&l2=8&l3=725&l4=0&model=2328&modelmenu=1
Input your info here to see if you need a power supply upgrade.
http://support.asus.com/PowerSupplyCalculator/PSCalculator.aspx?SLanguage=en-us
A little money for system memory would be good if you have less than 1 Gig.
You can test it here:
http://www.crucial.com/systemscanner/index.aspx
If you are saving money by not buying a motherboard and want to spend it (which is what I would do), I would put the money into a the video card and power supply.
Like this:
http://usa.asus.com/products.aspx?l1=2&l2=8&l3=726&l4=0&model=2705&modelmenu=1
And this:
http://www.amazon.co.uk/Netzteil-Corsair-620W-ATX-2-2/dp/B000KJNK8U/ref=sr_1_10?ie=UTF8&s=electronics&qid=1248740669&sr=1-10
I do not know the dimensions of the Aspire Case, so one thing to keep in mind is the dimensions of the card and the power supply. Make sure they will fit before buying.
If you start replacing motherboards and such, you might as well just go with a whole new system. A new motherboard, new CPU, new memory, new graphics, new power supply, fast hard drives, new case.
Posted on Jul 28, 2009
  • 5 Answers
SOURCE: MSI NVIDIA MCP73PV Motherboard will not boot
you fried your motherboard, buy a new one or a new computer, it's up to you.
Posted on Sep 17, 2009
Testimonial: "Thank you for you time"
Long beep on gateway computer
pls find the model no. and find the beep codes and match the order to identify the problem
ex:POST Beeping Error General Codes
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
Nov 07, 2016 | Gateway Computers & Internet
I moved a stick of ram and now my mobo wont recognize my graphics card
That is a memory error. Do you have 2 or 4 memory slots? In late model computers, they cannot be in adjoining slots, try moving to another slot.
May 24, 2014 | Computers & Internet
Gateway fx 6800 beep code
Try removing all the memory from the motherboard, then place a single stick of memory in the very first memory slot and see if it boots.
If the system then boots , add each memory stick that you removed back one at a time to determine which one is faulty.
Nov 30, 2013 | Gateway FX6800-01e PC Desktop
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
When i power on my gateway gt5662 i am getting an erroe beep that is one long and 2 short beeps the fan kick on but nothgin else does i tried to reset my graphics card i reset cmos i bought new bigger...
Beep codes usually indicate a hardware error. Take a look at Gateway's support page (link).
Three beep codes mean that you have a problem with your RAM. It might just be that it is not sitting correctly, so try to re-seat it into the slots.
Did you upgrade your memory or changed the sticks around?
One more tip: Try not to touch any metal and/or connections on the RAM stick, you might damage it and render it useless. Bad example here, good example here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 22, 2010 | Gateway GT5662 Desktop PC
I have abrand new Dell XPS 8100 with upgraded memory to 8mb and an ATI 5770 graphics card. When I start the computer I get 6 beeps and the PC does not start. Fitted a replacement Graphics card, still the...
Depending on the main board, 6 beeps usually signify's either a RAM issue (like a bad connection or incompatible ram) or an expansion slot issue so check any other cards you may have installed and make sure that The new RAM stick is compatible with the main board.. The main board model code is printed on the main board. Use it to search for audible fault codes, or go to www.upgrading and repairing computers.com and search for the beep codes for the main board on this site. Also, try reseating all the RAM sticks and expansion cards, especially graphics card..make sure you have not dislodged any data connectors and double check everything..
Feb 05, 2010 | Dell XPS 200 PC Desktop
MSI Graphics card keeps making computer lock up unexpectedly. Plese Help!!!
You could have bad memory or you could have shorted the memory out with a static charge while you where handling the memory. Try to get one stick of memory you know is in working order and which is of the proper soecifications for your system such as un buffered or buffered registered or non registered . You will need to know the proper memory required for your motherboard by researching the manufactuers web site for your model number of your motherboard. Some dimm slots are set in order [1,2,3,4,] you will need to locate the number 1, dimm slot and make sure you insert the memory stick in that location . While doing this make sure you discharge you body from a static electric charge by using a wrist ground strap or touching the power dupply metal case befor handling any of your pc parts as you install them ! I hope this helps .
Nov 24, 2007 | MSI FX5200-TD128LF GeForce FX 5200, (128...
My computer (emachines T5212) beeps at me
These are called beep codes and there should be a pattern of long and/or short beeps which will repeat. Once you identify the pattern we can help figure this out for you.
Jan 11, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
23 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
