Question about HP Officejet 5510 All-In-One Thermal Printer
Out of paper?
My HP 5510xi all-in-one has been working great until the other day.  It accepts a print job without difficulty and acts like it's going to print.  Then an error message comes up with "out of paper"  even though the tray is full of paper.  The paper just isn't feeding!
I've put a new print cartridge in and cleaned the rollers in the paper tray.  Help!  I'm a college student who desperately needs her printer for all the research papers!
Thanks -
Donna
  • 5 more comments
  • reckersooker Apr 15, 2008
    I have the exact same problem but the 5 step process didn't work at all. It still says out of paper. It makes all the same pre-print noises except the paper doesn't catch. Do you have any other ideas of how to solve this problem?
  • Anonymous Jun 23, 2008
    I have the exact same problem and the 5 step solution doesn't work. The Geek Squad says the barrings need servicing and suggest that buying a new printer would be more cost effective. We have run very few copies so the working life of this machine seems to be way too short.
  • Jim Rittinghouse Aug 04, 2008
    printer has been working great for years...
    just printed a batch of checks & start to print another and printer responds with out of paper error... checked everything obvious... no jams, rollers ok, paper ok, but will no longer pull paper into the printer. looks like the feed roller doesn't even move.
    Thanks for any suggestions
  • Anonymous Aug 28, 2008
    In my printer I can see that the wheel moving the paper does not turn.
  • bobgreen Sep 21, 2008
    out of paper but paper in printer.cleaner rollers and paper feed
  • LILREDZ560 Dec 16, 2008
    out of paper , out of paper no matter what you do OUT OF PAPER. WHEN ARE THEY GOING TO MAKE A PRINTER THAT WORKS LONGER THAN A YR. I GUESS THIS IS HOW THEY MAKE MONEY. THE INK WELLS GET FULL, THE ROLLERS DONT WORK ANYMORE. I THINK THIS IS HOW THEY KEEP MAKING MONEY BY MAKING PRINTERS THAT ONLY WORK FOR 3 MOS. JUST WHEN YOU RUN OUT OF INK AND BUY MORE THAN THE ROLLERS DONT WORK OR VISVERSA.
  • Don Verst Mar 17, 2009
    The paper pick up roller never moves, cannot find a paper sensor. The instructions from HP don't work. Any ideas?
  • 28 Answers
I hope this will help you but let me know if it doesnt i will get further into it with you
richard from chicago
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=311255
Issue An 'Out of paper' error message displays on the computer and the product does not pick up or feed paper from the main paper tray. Solution Complete the following steps in the order provided to solve this problem. Step one: Reset the product
  1. While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
  2. If the printer is not already on, turn it on by pushing the power button.
  3. Try printing again. If the issue is not resolved, continue to the next section.
Step two: Check the condition of the paper and reload it
  1. Replace any ripped, dusty, wrinkled, or bent paper. If the paper is curled, uncurl it by gently bending it in the opposite direction of the curl or replace the paper. NOTE: Use plain paper in the printer until the issue is resolved.
  2. Make sure that all the paper is the same size and type.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Load 10 to 25 sheets of paper in the paper tray. NOTE: Do not load too much paper in the printer.
  5. Insert the stack of paper in the paper tray, and then gently push the paper guides snugly against the paper.
  6. Make sure that the paper is pushed all the way into the printer. Use the rear paper guide or your finger to push the paper in until you feel a firm resistance. If the paper is not pushed all the way in, the printer will not be able to pick up the paper. If it is pushed in too far, the printer will pick up multiple sheets of paper, which can result in a paper jam.
  7. Try printing again. If the issue is not resolved, continue to the next section.
Step three: Adjust the paper settings in the print driver
  1. Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
    1. Open a document in the application in which it was created.
    2. Click File .
    3. Click Print .
    4. Click Properties . The Print Properties dialog box appears.
    5. Click the Paper/Quality tab.
    6. In the Size Is drop-down menu, select the paper size that is loaded in the printer.
    7. In the Type Is drop-down menu, select the type of paper loaded in the printer.
    8. Click OK . NOTE: These changes do not change the default print settings in the application. The print setting will revert to the default print settings the next time you open the application.
  2. On the Print dialog box, click OK to print the document.
  3. Try printing again. If the issue is not resolved, continue to next step.
NOTE: If the issue is resolved and you want to print on another type of paper, change the paper in the printer and repeat Step 2 and Step 3 . Step four: Clean the rollers
  1. Turn off the printer and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. Refer to the product User Guide for information on locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth lightly moistened with water. NOTE: Purified or distilled water is recommended for cleaning the rollers.
  4. Close the access door and plug the power cord in.
  5. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all of the steps listed above and are still experiencing a problem, service the product. Cause Any of the following problems may cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the printer.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rear rubber paper feed rollers are coated with dust.
Posted on Apr 07, 2008
I had walgreens fill my ink cartride and the printer worked fine for about 3 weeks now it won't print anything and the printer will no longer pull the paper through do I need a new printer or is there a reason for this. I keep getting a message that says my printer is not connected but it is because it worked about two weeks ago and it was all connected the same way then
Posted on Apr 16, 2009
Hp lj 4 plus accepts print job but does not print Vista Home Premium
Hello charles lewis,
Welcome, and thank you for using FixYa!
To answer your question: What you are experiencing is a driver type miss-match. The printer cannot understand the driver language that Vista is providing. Even though it is labeled as HP LaserJet 4 Plus.
I recommend trying the plain HP LaserJet 4 drivers or Lexmark Optra drivers. They may speak the language the printer likes, through Vista. If that does not work; it is time to purchase or use a newer printer.
Have a great day!
Oct 09, 2011 | HP LaserJet 4 plus Printer
I have a HP 5500 printer and I keep getting a print carr. error. docs won't print. Is there a patch or something i can do. I have tried cleaning and buying only HP carr. Please help Jeff
Is it a PRINT CARRIAGE error or a PRINT CARTRIDGE error?
Try accessing the manufacturer's web-site: http://support.hp.com
and enteringing '5510xi' and doing the search.
Then, click on "Troubleshooting" and read the online documents.
Jan 19, 2011 | HP Officejet 5510xi Printer
HP Officejet 5510xi All-in-One Printer Error: 0xf0af8004
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Feb 19, 2009 | HP Officejet 5510xi Printer
HP 8150 prints OK for 30 minutes then will not go.
I am certain you need to replace the tray one seperation pad. That will solve your problem.
I could walk you through it if you like. Very easy to do. Sep pad costs around $10 but it can be installed in two minutes. Easy.
Feb 14, 2009 | HP LaserJet 8150dn Printer
Hp 2600n will not accept print jobs. Color cartridges show empty. black shows half full. Printing of a test page produces a great test page quality
I have two problems. Either it won't accept a print job or when it is printing it stops when it is going through the job intermittently. Like for an hour it won't continue then all of a sudden it prints one page then a half hour later another page etc. It is so frustrating.
Feb 03, 2009 | HP Color LaserJet 2600n Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Photo paper jams.
please check the thickness of the paper maybe its too thick to print try a 180 gsm it will help.
yours
alecz
Mar 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
I'm going to go crazy!!!!!!!! HP PSC 1510xi All-in-one
Hi guys -
Well, I have to say - I have had HP printers for years and loved them - UNTIL I got an all-in-one! I have the 1315.
HP has NOT figured out the all-in-one printer package yet. There are software issues, and always always ink or paper issues. The scanner can be adjusted, but only so much, giving a really strange appearance to 3D items. Only paper items can scan well on it!
Overall, the best fix for an HP all-in-one is seriously to stop wasting time and ink and to get a different printer. I'd only had the 1315 for a month when I waived the white flag to wasting my time and effort. I bought a little cheap HP 3930, and it hasn't given me any trouble at all.
HP needs to work on the all in ones before continuing to market them. If you notice, there are new models constantly. That is because the figure out one issue, and instead of making a fix for it, stop support and put out a new printer instead, expecting everyone to just "upgrade" to the next new printer. Nope - not gonna happen.
What HP does have in its favor on printers, is that it is the only brand I've owned that didn't end up leaving "junk" on the paper - because of the printer cartridge heads, the prints are very crisp and clean, without overspray or dots.
Also very important on HP printers - be sure you get INKJET supplies if you bought an inkjet model. The papers are different, and many times, the laserjet supplies just won't go through their inkjets without jamming.
On the paper jam issues - while you cannot see a jam, it is somehow misreading the paper. Be sure you have the default paper size set correctly for what you are printing on. Also, take off the back and make sure there isn't just one piece of fuzzy paper back there. It doesn't take a full sheet of paper to give the paper jam error message - only a shred or slight piece where it doesn't belong. The track the printer heads run on is heavily greased and everything sticks to them! : (
I had to take the back off, used canned air to blow out the machine from the back, did it again from the front, uninstalled it and reinstalled it - that seemed to solve the paper jam issues.
I hope that might work for you.
Oct 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
1,216 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
