Question about Dell Inspiron N7010-JQ02DN1 17R Laptop PC - Intel Core i5-460M 2.53 GH
Reassembled Dell n7010 won't start at all!
Dismantled Dell n7010 laptop to clear laptop cooler. It went ok, but after assembling it, the laptop doesn't start at all. The only lifesign is when I connect the AC adapter, the right side led turns on for 1 second. Tried pushing power button for longer periods, with, without baterry, with and without AC adapter. Pls help!
    Top Expert:
  • Dell Master
  • 23,128 Answers
Here is probably a lead off. Have a look at this;
http://www.youtube.com/watch?v=AyR1mfzHrQk
Hope it helps.
Posted on Dec 26, 2013
Testimonial: "Already saw this video and did everything accordingly...I'm out of ideas"
3 Suggested Answers
  • 177 Answers
SOURCE: My dell D810 won't power up.
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Posted on Feb 18, 2010
zohail
  • 1223 Answers
SOURCE: Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Posted on Mar 07, 2009
Bought a dell inspiron n7010 laptop at a flea market and the bios is locked and dont know the password
Use google to look up bios hack its 2 pins inside ur pc thats next to a 9vlt battery on the mother board once u find the pins u have to short them out which will clear the bios
Aug 28, 2017 | Dell Computers & Internet
N7010 AC adapter not detected
Hi.
make sure your charger is good, if not buy another. Now if you are good will have to replace the motherboard
Apr 04, 2014 | Dell Inspiron 17R (N7010) AC Adapter 65...
Dell inspiron N7010 wot't turn on.
call tech support and get a complete diagnostics done.
Feb 19, 2014 | Dell Inspiron N7010-JQ02DN1 17R Laptop PC...
Need hdd password for dell inspiron n7010 laptop
eracing the hard drive wont work its a seting in the bios most times its admin or password if not then go into bios to remove it
Jan 14, 2014 | Dell Inspiron N7010 Laptop Core I3 2.4ghz,...
After reassembling Dell n7010 laptop it wont start at all!
Sounds like you have a problem with the motherboard. You might have zapped it with static electricity. Used motherboards are usually available for $130 delivered. Be more careful next time and avoid static electricity.
Dec 26, 2013 | Dell Inspiron 17R (N7010) AC Adapter 65...
How do you reset an admin/parental control password for a Dell Inspiron N7010?
dude i am not clear about ur question but i can tell if i email me ur problem at imanpal4@gmail.com i am sure i will answer
Jun 05, 2013 | Dell Inspiron B120 Notebook
Dell Inspiron n7010 doesn't charge at all
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 19, 2012 | Dell Inspiron Computers & Internet
Neptune front load washer stopped due to out of balance load. Now wont start turning, has a humming sound
went through the test program in the installation/service manual, which was taped to the back of the washer. It indicated that the drain .pump was not operating. Checked voltage to pump- OK at 116V. Pump was stalled and getting warm. Dismantled motor from pump housing and found impeller was stalled by a broken toothpick. Reassembled and washer now operating normally.
Jul 05, 2008 | Washing Machines
Dell Inspiron N7010-JQ02DN1 17R Laptop PC - Intel Core i5-460M 2.53 GH Logo
204 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
