Question about Black & Decker Toaster Ovens
Hualilai fz31 9e switch
Where to buy a switch
The oven does not heat up when I turn it on. what is wrong with it?
could be one of several things or several ,timer , switch ,element, fuse and on and on
Mar 17, 2015 | Toaster Ovens
Where can I buy the function switch for this oven
from the service agent spares or manufacturer spares
Apr 26, 2013 | KitchenAid KCO223CU Toaster Oven
I need to replace a dkj/1-60 timer for a toaster oven. Where can I buy the part?
You cannot find this part anywhere! I contacted the factory that makes them in China. They won't sell you one. Minimum order is 5,000 parts. I told them I was interested in a large order and asked if I could get a sample switch. They sent me 3 of them for the cost of shipping!!!!
Apr 18, 2010 | Black & Decker Toaster Ovens
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
I have Toast-R-Oven TRO200 and it just stop working.The light indicating the toaster or oven is being used does not come on.I plug it into other working outlet and it is still not working.
You probably have a switch in the oven that has failed or a broken wire. These are basically the only reason it wont come on. The best bet is if it is old buy a new one or see how much it would cost to repair. Usually the cost to repair is almost as much as the cost of a new one and getting parts can sometimes take two or more weeks.
Oct 09, 2009 | Black & Decker TRO200 Toast-R-Oven Toaster...
BLACK & Decker Countertop owen Model: CTO 649 does not work
Try smallappliance.com for your parts or just google search "small appliance parts" and you'll see a few places that have B&D parts.
Sep 19, 2009 | Black & Decker CTO649 Toaster Oven with...
Toster Timer Switch Broke
I had the same problem with the same exact switch DKJ/1-60. This part cannot be found anywhere but the factory and you'll have to buy 5,000 if you want one. There is another switch made for Delonghi that will work but it only has timer for toast. No 60 min. timer. The part # is 5218104600. This switch works the same way as the original but you will only have about a 13 minute timer. There is another one that has a 120 min. timer. The part # is 5218101800 for Delonghi. These switches look the same as the DKJ/1-60 but you may need to use parts from your old switch to mount these switches. Another solution to the problem is to replace the bad switch with a single pole single throw toggle switch that will handle 20 amp's on 120 volts AC. You will no longer have a timer and you will have to turn the oven on and off manually but at least you will be able to use the appliance. The above switch can be purchased at Gourmet Depot website for $10.98.
Jan 28, 2009 | Black & Decker CTO649 Toaster Oven with...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Toaster Ovens Logo
79 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
derbed
Level 1 Expert
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
