Question about Dell Inspiron 17R (N7010) AC Adapter 65 Watt Replacement (974833803346)
After reassembling Dell n7010 laptop it wont start at all!
Dismantled Dell n7010 laptop to clear laptop cooler. It went ok, but after assembling it, the laptop doesn't start at all. The only lifesign is when I connect the AC adapter, the right side led turns on for 1 second. Tried pushing power button for longer periods, with, without baterry, with and without AC adapter. Pls help!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 62 Answers
Sounds like you have a problem with the motherboard. You might have zapped it with static electricity. Used motherboards are usually available for $130 delivered. Be more careful next time and avoid static electricity.
Posted on Jan 04, 2014
  • 3 Answers
I would go back and double check all of your connections to make sure everything is connected properly and securely before purchasing a motherboard. That particular model has an AC Adapter Connector that has to be plugged in correctly to supply power to the motherboard. It's worth a try before spending 100+ on a used/new one.
Posted on Jan 07, 2014
4 Suggested Answers
  • 20 Answers
SOURCE: power
Look under the laptop. There should be button to push to the side(it has a lock picture). After pressing it the hard drive will come out( i dont know if it is a hard drive). After it comes out put it back again. It should help. It worked for me.
Posted on Aug 08, 2009
  • 679 Answers
SOURCE: when i m connecting ac
Hi Maxinfotech Its a common problem for DELL laptops. Most of the time the cause of this a bad AC Adapter but sometimes a firmware reset for the motherboard is the fix. I recommend you try replacing the AC adapter first than try to reset the firmware which could cause a system malfunction sometimes when not done properly. Thanks for using Fixya
Posted on Mar 01, 2011
  • 233 Answers
SOURCE: Inspiron 1545-my AC adapter doesn't seem to charge my battery
There are in a variety of causes about this situation. It could be improper use of the power adapter or because the battery is not being cared correctly. Besides, you can troubleshoot below possibilities.
Firstly, check if the AC adapter
is bad or not. Detach the battery from the laptop and turn on the computer with the power plug connected. If the computer does turn on, the power adapter is in good condition and not the cause the problem.If the laptop does not turn on, try using another power adapter to verify if the first one is defective. If the second trial does not work as well, the problem might be the power circuit of the motherboard. Look for a certified computer technician to help you solve the issue.
Secondly, If the notebook battery status is not being displayed correctly though software, it can be considered that the software is causing the problem and not really the battery.
Thirdly, test another known good ac adapter and try updating the bios if possible. check battery health meter for battery life status. Perhaps you need to replace the battery. but this issue is most likely an ac or motherboard issue. try running the 32bit diagnostic test using the drivers and utility disc.
If your laptop charger is malfunction and you plan to be on a budget on a new one, just try the following intocircuit laptop adapter:Intocircuit Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Posted on Oct 19, 2012
Bought a dell inspiron n7010 laptop at a flea market and the bios is locked and dont know the password
Use google to look up bios hack its 2 pins inside ur pc thats next to a 9vlt battery on the mother board once u find the pins u have to short them out which will clear the bios
Aug 28, 2017 | Dell Computers & Internet
Dell inspiron N7010 wot't turn on.
call tech support and get a complete diagnostics done.
Feb 19, 2014 | Dell Inspiron N7010-JQ02DN1 17R Laptop PC...
Need hdd password for dell inspiron n7010 laptop
eracing the hard drive wont work its a seting in the bios most times its admin or password if not then go into bios to remove it
Jan 14, 2014 | Dell Inspiron N7010 Laptop Core I3 2.4ghz,...
How do you reset an admin/parental control password for a Dell Inspiron N7010?
dude i am not clear about ur question but i can tell if i email me ur problem at imanpal4@gmail.com i am sure i will answer
Jun 05, 2013 | Dell Inspiron B120 Notebook
I went on vacation and when i came home my laptop computer wont turn on
Remove main battery and try again, next have the power supply adapter checked, if okay the DC jack in the laptop is a common source of trouble from no power to intermittent operation, at this point the laptop must be dismantled down to the motherboard level to address the problem further.
May 30, 2012 | Dell Computers & Internet
Dell Inspiron n7010 doesn't charge at all
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 19, 2012 | Dell Inspiron Computers & Internet
Dell inspiron 1525 - fan starts running loud and
Are you using this laptop on a bed or somewhere where the ventilation os obstructed on the edge or the underside of the laptop? This is very important to check. Is this problem happening at startup?
Anyways hope this helps
Mark
Aug 23, 2009 | Dell Computers & Internet
Touchpad on dell vostro wont work
Sounds like a short to me...you probably missed some liquid as it does not take much...go thru the process again. I know thats not what you wanted to hear...but liquid on those things is a nightmare and you just never know where some of it went. A complete drying is in order...if it was a sticky liquid like soda....even when "dry" it can still short it out. If it was water...double check you got all the water...then let it sit out for a day.
Apr 24, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Neptune front load washer stopped due to out of balance load. Now wont start turning, has a humming sound
went through the test program in the installation/service manual, which was taped to the back of the washer. It indicated that the drain .pump was not operating. Checked voltage to pump- OK at 116V. Pump was stalled and getting warm. Dismantled motor from pump housing and found impeller was stalled by a broken toothpick. Reassembled and washer now operating normally.
Jul 05, 2008 | Washing Machines
Dell Inspiron 17R (N7010) AC Adapter 65 Watt Replacement (974833803346) Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
