Question about Archos 101 Internet Tablet Notebook
Error fix parse error
Parse error therecis a problem parsing the package what dose this mean?
I just bought a new tablet its called Emerson . when i go set up a google account after i put my informarion it says Unfortunately,Google play services has stopped. What dose that mean?
Hi If U have logged in OK type in Google search.:::: Google play app download .:::::: it should open a page .for play app download . Cheers
Dec 15, 2016 | Tablets & eReaders
My tablet won't let me download any apps. Says it's parsing??
Have you checked storage make sure you have room and, try reseting it. Or run back up, if you have it. Also connect to it to your pc and try manually to put apps on. Factory reset and use sd card when you load everything back if you can load the store app on sd, if it happens again you can remove sd delete store app of it and do it again good luck
Jul 04, 2015 | Tablets & eReaders
How to fix white screen upon turn on
if it has not been dropped or water damaged you can try a factory rest ( loosing everything ) Turn off tablet and hold the volume up button and the home button together,then turn the tablet on ( keep holding the volume up and home button ) when tablet starts it will show you a secret menu, you can try rebooting it first from that menu and if it still dose the same thing,if it dose then repeat the steps again but go for reset. ( this will wipe it clean,you will loose everything,so only do that as a last resort ) hope this helps
May 27, 2015 | Tablets & eReaders
What can I do to recover iPad lost photos?
To recover iPad photos you can try Amacsoft iOS Data Recovery, we can use it to recover lost iPad data with/without iTunes backup file. And we can also use it to restore iPhone and iPod data in the same way.
iPhone Photo Recovery Retrieve Lost Pictures from iPhone
Apr 23, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I was trying to install games from my app store on my tablet why did parse error appear
I would recommend restarting your tablet and trying to redownload the app. Usually a a parse error occurs when there is compiling error with the package (app's data).
Essentially it might not have downloaded correctly so restarting the whole process should skip it right along!
Apr 08, 2014 | Tablets & eReaders
How to fix an android parse error
Upgrade it.Search it on Google, or call the supplier and see if they have good method.
Android 4.0 Tablet PC
Jan 13, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
Solution
uninstall and reinstall the application that's causing the error, you probably have the installer package somewhere on the laptop if it came pre-installed.
try to remove it from the auto-start list.
Feb 12, 2009 | Toshiba Portege 3500 Tablet PC
Archos 101 Internet Tablet Notebook Logo
67 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
