Question about Ingersoll Rand Air Tools & Compressors
LOW SUMP PRESSURE SHUT DOWN - Ingersoll Rand Air Tools & Compressors
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
More info would help but if it is shutting down because of "low oil" then you can do one of two things but first make sure the oil is at the proper level
unplug the low oil safety switch...
fix it correctly
next time, let us know what kind of engine you have and model numbers of everything involved
Posted on Dec 30, 2013
Why doesn't it start?
Usually when a coupler breaks the machine will shut down from low sump pressure. Did you reset the alarm from that?
Feb 29, 2016 | Air Tools & Compressors
Low oil pressure shut engine off. That's what I am getting on my 93 cadillac seville 4.9l after I changed the oil today.
did you put the plug back in the sump or did you remember to put the correct amount of oil back in the sump oil
sender problems will not occur just like that after an oil change
Sep 19, 2017 | Cadillac Cars & Trucks
Low sump pressure
well with out a model number this is a tought one , but if your unit is less than 10 hp the low sump pressure is most likely caused by a dirty suction screen or worn out oil pump if its over 10 hp then low sump most likely is caused by a dirty inlet air filter
Mar 18, 2014 | Ingersoll Rand Air Tools & Compressors
Check sump pressure? can you tell me what that means
Sump pressure is the back pressure created within the oil sump by pressure leaking past the piston rings. The pressure is usually very low due to the venting of the sump thru the oil sump vent (usually a tube or removable plug used for adding oil). If the vent was replaced with a plug, then pressure will be very high and cause oil leak. Higher sump pressure is also caused by adding too much oil into crank-case. If you are having other problems with compressor, post again. Good luck.
Dec 26, 2013 | Air Tools & Compressors
Low sump air
I think you have this posted in the wrong section, this is for car and truck problems. Please re-post in correct category.
Jun 15, 2012 | Cars & Trucks
SSR EP 40 SE shuts down on low unload sump what is probable cause
I would look at the minimum pressure check valve first. If it is stuck in the open position you can not build sump pressure before the unit shuts down. MPCV is located on the top of the separator tank. You can remove it. Check to see if the plunger with the teflon disc is free and not damaged. These valves often seize up due to dirt,rust and condensation. If it is stuck it will need to be disassembled, cleaned and lubricated. It needs to be free enough to slide in the valve body by hand. If the o-ring is bad or damaged you will need to get a kit from IR. I have not been able to find one with out buying a kit. Next I would look at the blow down valve. It is located beside the MPCV at the top of the separator tank. If this solenoid is open it will not let the sump build pressure. Next I would check the Inlet valve actuator cylinder if so equipped. With out the serial number I dont know which type inlet valve is on the unit. If it does have a cylinder does it operate correctly. Is there any free play in the cylinder. If so replace it. Is the cylinder to inlet valve coupling cracked. Remove and inspect. Is the bolt tight at the rear of the cylinder. Will it let the cylinder move. If so you will need to loosen the bolt. Set the controller so you can see sump pressure. Start the unit and Slowly open the inlet valve by sliding the cylinder in and out to get 25psi sump pressure. Then tighten the bolt. if sump pressure drops below 15 psi it will shut down on sump pressure alarm. Good luck !!!
Aug 30, 2011 | Ingersoll Air Tools & Compressors
Low sump pressure
compressor shuts down on low sump pressure
Oct 19, 2009 | Ingersoll Rand Air Tools & Compressors
Air Tools & Compressors Logo
323 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
