Question about STEREO ADVANTAGE INC Motorola MB140R - 10-mile Talkabout Rechargeable Two-Way Radio - Brown
Hi.. My problem is that the unit is only in TX, press any botton only TX. How do I for the solution?
  • STEREO ADVAN... Master
  • 1,654 Answers
  • A few things to check.
    If you are using an audio device, you must have the radio turned off when plugging/unplugging any audio device.
  • Check to be certain you do not have a VOX (voice activated) feature turned on.
Best regards.
Posted on Dec 27, 2013
We have a Canon 810 Fax Machine. How can we change the fax header?
change unit name
press additional functions button
then use the arrow - + buttons to select
tx/rx settings press ok
tx/rx common set.
tx settings
unit name
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
page 333 or section 12
Oct 28, 2016 | Canon Laser Class 810 Plain Paper Fax
Is there a way to reset onkyo tx-ds494 receiver
HI Preshay, to reset the tx-ds494 first press and hold Video 1 then also press and hold Speaker A, the display will show Clear then the unit will shutdown. Please note that everything will revert back to factory defaults so it will be like taking the unit out of the box for the first time. If you need further assistance please contact our Product Support Team at 800-229-1687, Thanks, JT
Apr 16, 2015 | Onkyo Audio Players & Recorders
How to check voice messages from coreded base L702c model, or how to turn answering options on from the base unit
Hi, in idle state, from base unit press cassette icon botton (mute), the messages will be played from newer to older.
Oct 07, 2012 | Motorola Mobility L702C DECT 6.0 Telephone
# 3 and H Flashing ... will not do anything else ?
TO RESET THE MACINE PRESS THE ORANGE BOTTON (C),PRESS THE BOTTON UNDER THE AUTO DENSITY LIGHT,RETURN TO THE FIRST ORANGE BOTTON THEN THE AUTO DENSITY BOTTON, YOU HAVE TO BE FAST WHEN PRESSING THE BOTTONS, ALL THE LIGHT ON THE DISPLAY WILL GO OFF THEN PRESS 14 AND PRESS THE GREEN PRINT BOTTON,THE MACHINE WILL RESET AND START TO WORK, BUT IF THE PROBLEM COUNTNUE CHANGE THE FUSER UNIT.
Sep 10, 2010 | Sharp AL-1000 Copier
When I press the botton next to power button in order to activate the bruch for carpet cleaning. The brush does not spin anymore.
HighnTools posted this solution a while ago. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
May 21, 2010 | Dyson DC15 All Floors - The Ball Bagless...
How do you turn rca Lyra RD1080 128MB player on?
Theres to main bottons press and hold the right one for a second then the unit should fire up and to shut it off press and hold the lower left botton and then it will shut off.
Feb 08, 2010 | RCA Lyra RD1080 MP3 Player
No audio out
Have you check the button Tape 2/ Monitor not have bin set to on? If you press this botton all sound is gone no mather what other button you are pressing.
Regards
Peter
May 04, 2009 | Onkyo TX-SV646 Receiver
Wont stop printing TX report!
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgmoz-screenshot-3.jpgHere are some of the instructions you'll need, but you can also find more assistance by accessing the online Canon support site and searching the exact error message you get. (click here)
ssue:
ERROR LCD: INCORRECT PAPERSIZE
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Here are instructions for changing the setting of the tx report:
Issue: How do I change the TX report
Solution: Changing the TX Report-IC D/PC 1000 Series
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif > to select [FAX SETTINGS], then press <Set>.
  3. Use <la.gif > or <ra.gif > to select [REPORT SETTINGS], then press <Set> twice.
  4. Use <la.gif > or <ra.gif > to select the option you want.
Name Description TX REPORT 111OUTPUT NO
111PRINT ERROR ONLY
111REPORT WITH TX IMAGE
111111ON
111111OFF
111OUTPUT YES
Enables/disables automatic printing of a transmission report. No report is printed.
Prints a report only when a transmission error occurs.
If you select PRINT ERROR ONLY or OUTPUT YES, enables/disables printing of the first page of the fax under the report.
Prints a first page only when a transmission error occurs.
The first page is not printed.
Prints a report every time you send a document.
(The factory default setting is in bold face.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
I have a xv n330 dvd player and it says lock when I try to take out the dvd in the player and it says lock.
When you press the eject botton while pressing down the stop botton on the unit in
standby mode, the tray lock function is activated. The disc tray
cannot be opened or closed in this status. To release this
status, press the eject botton while pressing down the stop botton on the unit in standby
mode.
Mar 01, 2009 | JVC XV-N330
STEREO ADVANTAGE INC Motorola MB140R - 10-mile Talkabout Rechargeable Two-Way Radio - Brown Logo
Top STEREO ADVANTAGE INC Radio Communications Experts
eradiostore
eradiostore
Are you a STEREO ADVANTAGE INC Radio Communication Expert? Answer questions, earn points and help others
