Presario v6500 manual
My hp compaq presaro v6500 motherboard damaged can i upgrage this to higher version with 4 gb or other
  • 5,259 Answers
Generally upgrading the motherboard is easy, as long as it fits in the case. However it's what goes on the motherboard that will cause you problems. For example if you are fitting the old memory cards and the processor any other cards that fit into the slots, they might not work with the new board, so you could finish up replacing them too!
Posted on Dec 27, 2013
  • 19 Answers
SOURCE: compaq Presario 5321 SR motherboard
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
adfsdfs5
Posted on Sep 08, 2009
Geekman
  • 32281 Answers
SOURCE: Compaq Presario V6500 has on board graphics card a
You can install a better graphics card in the AGP slot. You most likely need to disable the on board graphics card from the BIOS.
Posted on Dec 11, 2010
joecoolvette
  • 5660 Answers
SOURCE: My hp compaq Presario V6500 has been damaged and a
The monitor screen on your laptop is an LCD screen.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
The additional light source is a Backlight.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
LCD screens are a composite of layers. The layers are held together by a metal frame, much like a picture frame.
The Backlight is usually located on one side, accessed after removing one side of the metal frame.
As stated, a Backlight is a very small type of Fluorescent lamp, (Tube)
Very fragile, easily breakable, and not usually approached by one who has very little, or no experience in replacing.
More common the entire LCD screen is replaced, which includes the Backlight already installed.
A laptop also needs an Inverter to provide power, both for the LCD screen, and the Backlight.
90 percent of the time the fault is the Inverter.
I repeat, 90 percent of the time the fault is a bad Inverter.
An Inverter is cheaper than an LCD screen, and MUCH easier to replace than a Backlight.
Allow me to show you replacing an Inverter on an HP Pavilion dv6000 series laptop.
Granted, it isn't an HP Compaq Presario V6500 series, but the principles still apply the same,
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
I can also provide a free link, to the Service Manual for an HP Compaq Presario V6500 laptop, direct from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3369429&
In the list click on;
Compaq Presario V6500, V6600, and V6700 Notebook PCs-Maintenance and Service Guide
This is a PDF file.
Allow up to 30 seconds to see the first page, and an additional time may be needed to fully download.
In the Bookmarks menu on the left click on the + sign next to;
1) Removal and replacement procedures
2) Component and replacement procedures
3) Display assembly
And/or go directly to Page 61 to view the Inverter location.
One example of an Inverter for an HP Compaq Presario V6500,
http://www.sparepartswarehouse.com/Compaq,Presario,V6500,Laptop,Inverters.aspx
Granted this is not what you asked for.
My premise is to teach, and hopefully save people money.
If you have additional questions please state in a Comment.
Regards,
joecoolvette
Posted on Mar 06, 2011
  • 2226 Answers
SOURCE: i have compaq presario V6500
check the board caps to see if there are any mushroom up if so board bad jim look at the x on the tops
Posted on Mar 24, 2011
bronk50
  • 27725 Answers
SOURCE: hp compaq v6500 bios in uuid 0000000000000
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Posted on Sep 09, 2012
http://h10032.www1.hp.com/ctg/Manual/c01295079.pdf
Dec 26, 2013 | Computers & Internet
When esc key pressed only starting my presario v6500
disconnect the keyboard from motherboard.then checkif problem not occured it means problem from keyboard, then replace your keyboard.
Jun 24, 2012 | Compaq 449901-001 - HP Presario V6500...
How to blow hot air gun on gpu presario v6500
I don't recommend it because it is not a proper repair. May last a week, a month, or a year. Hard to say.
HOWEVER, that is not what you asked.
IF you are going to do it, then follow this guy's method, (Minus the torch),
http://www.youtube.com/watch?v=JEpnqhRYGLw
Regards,
joecoolvette
My hp compaq Presario V6500 has been damaged and a computer dude in Bathurst NSW said we need a bulb replaced in the screen as it won't light up. Computer functions via TV. R there any local repairers for...
This is a PDF file.
3) Display assembly
Regards,
joecoolvette
Mar 06, 2011 | Compaq 449901-001 - HP Presario V6500...
I have 2GB memory in my compaq Presairo V6500 Can I upgrade to 3 or 4GB
Yes you can definitely upgrade to a 3 GB. As for the 4GB, i can't really say.
You see, most systems or motherboards comes with a specific limit of the RAM capacity or processor which they can handle.
The best thing to do is to go through your manual and depending on the exact specifications of your motherboard, you should see the specific capacity which your system is allowed to operate with. This is because, the limitations vary from each system depending on your specifications.
If you cannot locate this, you can call a technician over and he would help you go through the motherboard and tell you the exact limit of your system.
Hope this helped you?
Jan 23, 2011 | Compaq 449901-001 - HP Presario V6500...
Compaq Presario V6500 has on board graphics card a separate card be installed, are there any options.
Dec 11, 2010 | Compaq 449901-001 - HP Presario V6500...
Can i upgrade the memory on my v6500
ya man u can do if u have the extra slot and make sure that the ram is compatible with the motherboard
Feb 21, 2010 | Compaq 449901-001 - HP Presario V6500...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
