Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Idles rough i have a 1995 1500 350 4x4 idles rough idle up and down .
    Problem Solver:
  • 14 Answers
Do you know if you have a mass air flow sensor on that year and make?Also sounds like a possible vaccum leak,or egr valve.My car has a maf sensor,and it was doing the same thing.I cleande it and the problem went away.
Posted on May 18, 2009
Chrysler rough idle and rough idle when stopped in drive
check for loose/ missing vacuum lines on the engine . Easy enough when replacing an engine.
Feb 24, 2014 | Cars & Trucks
REPLACED THE EGR VACUUM SOLENOID NOW IDLES RUFF AND RPM GO UP AND DOWN AT IDLE
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues.Engine idles rough.There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------Click the link below:-----Bad miss at idle? http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild? http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
--------- Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
---------- Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
GMC Sonoma Stalls and idles low http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting? http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
-----------While stop engine idles like cylinder missing? http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
---------These details will help.Thanks.
Nov 23, 2012 | 2001 Ford Escape
My Chevy 2500, 2001 runs rough when it cold outside
It can be issue with low fuel pressure,the fuel pump is getting old both needs to be checked.Also get the IAC valve checked.
Go through the related help links with similar problem,it may help:---
Click the links below:---
Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Car still runs Rough after tune up?
http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
2006 kia rio runs rough http://technoanswers.blogspot.com/2012/10/2006-kia-rio-runs-rough.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
Thanks.
Nov 06, 2012 | Cars & Trucks
I have 1999Chevy suburban with 6.5 turbo diesel motor.it idles up and down and when driving the gas pedal is real touchy Wat is the problem and were do i locate the problem
Check the help links related to this problem.Click the link below to go through its troubleshooting procedure :-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html---------
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
-------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down?
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
After replacing brake rotors and pads, brake pedal remains on floor? http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
accelerator pedal sensor? http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
For rough idle issues and problem troubleshooting,go through the help links provided below :----- van idles rough?
will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
This will help.
Thanks.
Mar 01, 2012 | 1999 GMC Suburban
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Feb 17, 2012 | 1992 Nissan Pickup
88 dodge dakota has rough idle and stalls at slow down.
Change/thoroughly clean the idle control solenoid. It may be sticking and causing rough idling.
Cleaning it is unlikely to be more than a short-term solution.
Jan 07, 2009 | 1988 Dodge Dakota
Rough idle, steady idle of 1500rpm's when you crank, jerking down the road with idle jumping
1999 Surburban. Rough idle when engine is cold for about 3-5 min and then it starts to smooth out. Any ideas why the engine would act like this?.
Aug 02, 2008 | Chevrolet Cavalier Cars & Trucks
Idles rough with engine
1. idles didn’t adjust right.
2. check the timing
3. check your fire order
4. check your distributor cap. Maybe it is leaking
Jul 06, 2008 | 1999 Jeep Cherokee
Rough idling and lopes
oxgen sensor needs replacement this controls the air flow
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
216 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
