Question about Apple iPod touch
The clicker located at the bottom, center of my ipod touch stopped responding and ive already re-started multiple times. what do i do? the serial number is: 1B741YS1W4T
    President:
  • Apple Master
  • 688 Answers
It is possible the the button is just stuck or crooked in the cradle it sits in.
when you look at the ipod is the square on the button turned at all if so push it with your finger and turn to straighten it. it has 2 channels it is supposed to line up with.
also maybe it is dirty and stuck down. try clean around the edge with a qtip with alcohol but not so much that it is wet.
If this doesn't help you may have to have a tech open it and see why the button is not responding.
Posted on May 18, 2009
What generation this iPod is serial number 1A009QC075J
iPods come in a variety of generations and models, including the nano, Classic and Touch. Depending on your model you may be able to record video, play games or watch television.
If you're unsure of your device's model, you can determine which iPod you have by using your serial number.
After determining your model, you can find out which features and capabilities your iPod has.
Go to Apple's official website (see Link Below) and click the Support tab.
http://www.apple.com/
Click the Online Service Assistant link, which is located in the Support Services menu on the right side of the screen.
The Service and Repair page will open.
Find your iPod's serial number.
This is engraved somewhere on the back of your iPod, either on the body of the device or on the clip.
You can also find it in your iPod's About screen by clicking Settings and selecting About (or General followed by About on an iPod Touch).
Enter your iPod's serial number and click the "Continue" button.
Your iPod model and generation will be displayed at the top of the screen.
http://support.apple.com/kb/HT1353
also
With each new generation of the iPod Touch, you get new features and updates to the older generation.
The 2nd and 3rd generation iPod Touches are very similar in physical appearance.
The easiest way to determine what generation of iPod Touch you have is to check the model number on the back of the device.
The 2nd and 3rd generation iPod Touches were given unique model numbers to help distinguish your device generation.
Remove any protective case from the iPod Touch so you can see the back of the device.
Locate the model number at the bottom of the back of the device.
Check the model number against the following model numbers.
Third generation iPod Touches are model number "A1318." Second generation iPod Touches are model number "A1288."
Identifying iPod models
http://support.apple.com/kb/ht1353
Aug 10, 2013 | Apple iPod touch
Tip
How to remove songs from your iPod Touch 2
<p>The second generation iPod Touch, also known as the iPod Touch 2, was in storage sizes of 8 GB, 16 GB and 32 GB. Depending on the model, he may never need to remove songs to free hard disk space. If you find yourself in tight space, or low-end version 8 GB or more 32 GB mode settings, use iTunes to manually manage the songs on the iPod Touch. <br /> <p><br /> <p>1. Hook touch to your computer using the USB device. <br /> <p><br /> <p>2. Open iTunes. The program takes a while to read and display the name of his touch in the source list left. <br /> <p><br /> <p>3. Click on the name Touch the left in the source list. <br /> <p><br /> <p>4. Click the "Manually manage music and videos" box, located at the central, if not already selected. This mode is used for music from your iTunes library once the iPod touch in the library computer. <br /> <p><br /> <p>5. Click the "Music" option in a list of source Tap the left pane. Touch your music will appear in the center pane. <br /> <p><br /> <p>6. Click the number you want to delete. If you have multiple numbers, hold down the "Ctrl" and click on the numbers. <br /> <p><br /> <p>7. Right-click a selected song and click "Remove." <br /> <p><br /> <p>8. Click "Remove" to delete the song (s). <br />
on Aug 05, 2011 | Apple iPod touch
Why does my iPod keeps turning itself on when I lock it?
iPods have no traditional on/ff switch. They power up with the slightest touch, which makes turning the iPod on as simple as touching the menu. Turning the iPod off, however, can be more tricky. Waiting for automatic shut off wastes battery life, and surfing the menus yields no way to stop the device from running. Turning off the iPod Nano, though, is almost as simple as turning it on.
Locate the "hold" or "lock" switch at the top of your iPod Nano. It will be located on the top of your device on the left side. Make sure the device is unlocked. When the device is locked, an orange bar is visible. When it is unlocked, that bar is not visible. The iPod needs to be unlocked in order to power off. Locate the "play/pause" buttons. These are located at the bottom of the control wheel. Press at the "play/pause" section of the wheel and hold for a few seconds. Your iPod will power off. Do not touch the wheel again after powering off, as this will power the device back on. Locate the "hold" or "lock" switch again. Slide the bar to the locked position so that the orange bar is visible. This will prevent your iPod from powering on in your purse or pocket and wasting battery time.
Feb 08, 2013 | Apple MB735LL/A 8GB 4th Gen iPod nano -...
My Ipod Touch lags on start up/loading playlists and freezes sometimes
font.f1 { font: 12px Helvetica; } Thanks for asking your question with Fixya Support. I will be glad to assist you.
The simplest approach to resolving an issue like this with your iPod Touch is to perform a reset, which in essence "reboots" your iPhone and can improve its performance. Not to worry, a hard reset process does not endanger any of your playlists, videos, podcasts, etc., which you may have on your iPod Touch.
All you need to do is press the Sleep button, located at the top of your iPod Touch and then the Home button located at the bottom center-most location of your iPod.
Hold both buttons down at the same time for approximately 10 seconds. Within that time you should see an Apple icon appear as your iPod Touch attempts to reboot. Allow it to go back to your main screen. Now attempt to use the device as you normally would and see if it improves.
I would also recommend you connect your iPod Touch to your computer and check in iTunes- if I am not mistaken, there is a new iOS 4.3 update just released from Apple, that you can run, if you have not done so already. It is always good to keep your iPod Touch up to date with the software updates, as those updates can resolve the bugs of the previous iOS version.
This should help, but please feel free to let me know if it does not. Always glad to assist!
Regards,
-Mactechtrainer
Mar 14, 2011 | Apple iPod touch
My silver ipod nano third generation is not working, all the buttons are not working the center button and the circle clicker button isn't. I have restarted it and erased everything off it and there is no...
goto the website http://www.felixbruns.de/iPod/firmware/
and download the selected firmware for the ipod touch model you have. if your unsure if the model / type you can goto http://www.felixbruns.de/iPod/firmware/#
and type in the last 3 numbers of your serial number to find out
if you want to downgrade or upgrade, choose the firmware you want to downgrade to, then go to itunes and shift-click on restore and choose the firmware you want to change to. this will restore your ipod touch
Sep 09, 2010 | Apple iPod nano
My Ipod touch 16G first generation. wont respond to my touch even to turn it off. its at the screen where it says slide to unlock and it wont respond to my touch.i havent dropped it and its in excellent...
1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
2. Open iTunes and sync the iPod as normal.
3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Oct 31, 2009 | Apple iPod touch
IPod Touch Automatically Reverts to Main Menu Screen
you need to restore your ipod touch by connecting it to your computer and clicking restore. make sure you have backed up your ipod touch before you do this or you will lose everything on your ipod touch.
Jun 16, 2009 | Apple iPod touch
The center clicker of my ipod touch does not respond when pressed.. what should i do? ive restarted it several times and the guys at the apple store just said buy a new one because there's nothing they...
the button on your touch could be stuck down. hold you touch in front of you and look at the square on the button. if the square is off, push the button and attempt to turn the button and get it back into it's groove. it has 2 ears on the sides that are supposed to be in a indentation.
if you can't get it that way it may need to be disassembled and fixed.
May 17, 2009 | Apple iPod touch
IPod Touch Menu Button Problem
To refresh your iPod Touch. Hold your Sleep/Wake Button and the Menu Bottom at the same time for 10 seconds. It will close and comes back again with the apple logo. Wait until it starts correct.
If it doesn't, restore your iPod into factory settings.
Mar 14, 2009 | Apple iPod touch
Apple iPod touch Logo
44 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
