Question about Mint Plus Automatic Floor Cleaner with Charging Cradle - Model 520
Mint model 5200 only goes backward, red light flashes 5 times
Mint model 5200. Turned power on, pushed teardrop icon button and unit starts going backward for a short distance, stops and the red light on the unit flashes 5 times
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
My purple Dyson Animal (without the ball) isn't working correctly. When I turn it on, the red power light, as well as the medium pile buttons flashes. When I first turn it on, the brush rotates for 3 to...
I need help repairing my Dyson. I cannot push the buttons down to select Short pile/Medium pile or bare floor. The buttons will not push down at all. It will not allow me to select anything. I have very short pile carpet so it does not pick up that well.
Oct 23, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
Hoover Wind Tunnel 2 won't stay on
Possible that the switch is bad, part #40309033, take the handle off, then the tool compartment, then you can get to the switch, almost bet that one of the contacts is bad.
Feb 20, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
Mint Plus Automatic Floor Cleaner with Charging Cradle - Model 520 Logo
98 people viewed this question
Top Mint Vacuums Experts
JoeVacs
Are you a Mint Vacuum Expert? Answer questions, earn points and help others
