Question about Refrigerators
Fridge isn't cold and the alarm light stays on, before it happened the fridge started "gurgling" alot!
  • 2 more comments
  • woodward_3 May 18, 2009
    Hi Localwonder,
    Yes, very occasionally the compressor will come on and seems alot louder than before, its not "gurgling" so much but it is still warm inside?
    Cheers
    I've just checked and the colis are frozen over!?
    Yes please!
    its a Teka A - FCI340
  • Michael Masters
    Michael Masters May 11, 2010
    Hi, is the compressor making a lot of noises and is it cycling on and off in a abnormal pattern?
    Are the coils frozen over?
  • 6,784 Answers
Ok, this will confirm a major compressor fault. the main seal has failed. you will need to replace the compressor in order to restore the unit to its original cooling state.
If you can give me the model number and brand of your unit, i can direct you to some reasonably priced compressor kits if you would like.
Posted on May 18, 2009
  • Michael Masters
    Michael Masters May 18, 2009
    Ok, it took some time but, i have found a site that you can order all the parts you will need for your TEKA A-FCI340. you will need to order the compressor and temperature sensor as well. this Will fix your cooling issue. click the link below to be directed to the parts.
    CLICK HERE FOR YOUR TEKA PARTS
    Please rate and have a great day:)
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
I have a Performa side by side 7 years old, had a repairman out because it started running constantly...Dx was there is a freon leak. Isn't this uncommon for a fridge that is not THAT old?
It happens alot in my 18+ years i have seen them leak 1 day later to 30 or 40 years later.If it was running and not stoping and freezer and fridge warm or hot it may be a leak if it runs alot and freezer is cold and fridge warm then it is not a freon leak.
May 18, 2010 | Refrigerators
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Fridge not cold
take back panel off. feel the motor on compressor. is it warm or cool? make sure the condenser coil is not clogged with dirt.
Dec 07, 2007 | Refrigerators
Refrigerators Logo
268 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
