Question about Brookstone Cloud DSS Long-Range Copter
I am looking for replacement parts for my Cloud DSS Copter. Is there another name this copter is sold under or maby the manufacturers name? I need the tail rotor drive gear. Thanks
Air Hogs R/C pocket-copter not functioning
your copter might have already experienced some hard bumps or landings , so you might need to check your copter circuit and battery cables to make sure they are in good condition or check the battery itself.
May 02, 2015 | Spin Master 1001130 Air Hogs R/C Pocket...
Brookstone cloud DSS copter will not stop spinning out of control and trim buttons will not fix it, what else is there that I can do to fix this problem.
many reasons for this, first tail rotor, then controller. but if the tail rotor in not working all it will do is spin just like the real ones I flew in the military.
Dec 30, 2014 | Toys
How do you charge the cloud dss helicopter
The copter's battery is charged with an ac adapter power unit model number - 3PL0508S, hope this helps.
Jul 05, 2014 | Brookstone Cloud DSS Long-Range Copter
Need parts /brookstone cloud dds
Go to Ebay and search for replacement parts for the Double Horse 9116. They will fit your Copter. I have four of them. Also visit www.propelrc.com. and browse spare parts and find your model.
Mar 28, 2014 | Brookstone Cloud DSS Long-Range Copter
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
My helicopter won't take off, it just spins in circles clockwise until it falls over. It's a 4 channel RC helicopter with gyroscope.
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Jun 06, 2011 | RC Remote Control Helicopter Ready To Fly
"greensbr" did you ever find a source for broken
Hi Glen,
Your request was quite a chase with most links pointing back to this forum or to hobby shops where our iwave copter just does not exist.
We do have expert help here to solve our problems but at $12 $16 or $20 this is simply a ridiculous price to pay for one wanting a simple parts manual.
I finally googled iwave+customer support and came up with this link which shows some promise.
http://www.enigmatec.net/community_customers_support.html
I sent an email to the address listed in the link but have not recieved a reply at this writing. What I would like to have is an extra battery pack for the Copter.
If you do not have any luck with this, It is my thought that the iwave copter is manufactured by another company and sold under the iwave name. There are hundreds of different models of RC copters out there so it is my thought that you could probably go to a hobby shop that sell's these accessories with your "good rotor" in hand and they could probably match it up for you.
Please feel free to add a "comment" to this as we can keep each other posted on the return mail from support@iwave.com
Jan 09, 2011 | Jumbo RC JUMBO HELICOPTER
Brookstone Cloud DSS Long-Range Copter Logo
88 people viewed this question
Top Brookstone Televison & Video Experts
L Pfaff
L Pfaff
Tom Chichester
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
