Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Why do i smell gas? - Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
    Sergeant:
  • 236 Answers
Either one or more of the hobs or oven may be turned on but not lit or there is a leak. Check all controls are turned off, if you can still smell gas I would recommend turning the gas off at the meter point and calling either a professional gas fitter or the gas emergency services. It would also be wise to not smoke and open a window or door until the gas smell has gone.
Posted on Dec 26, 2013
Smells gas
I am only guessing but I would thoroughly check the fuel lines and gas cap.
Aug 24, 2014 | Cars & Trucks
1991 mazda 626 smells like gas sometimes it smells more then other times
My 626 smells like gas if I fill the tank to full. Must be a bad connection on the top of the tank.. Doesn't smell if I don't fill it over 3/4.
Feb 17, 2013 | 1991 Mazda 626
Gas smell inside maytag neptune gas dryer
gas has an oderant added to it and in your dryer in the cool down it allows most of the gas to be removed.if you smell gas when the dryer is off and empty, then you have a gas leak.thanks karl
Jan 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Smell of gas
Turn off any electricity to your heater, if after a while the gas smell goes away then you might have a low voltage problem. Otherwise the gas valve inside the unit may be defective. If you smell gas don't fool around with safety. Pipefitters and Gas Suppliers may be of little help, get a trained HVAC Tech. Good Luck
Jul 09, 2009 | Heating & Cooling
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
2005 Dodge Durango gas smell around gas cap area
NO NO NO.....GO TAKE YOUR VEHICLE TO A SMOG STATION AND ASK THEM TO TEST THE GAS CAP FOR YOU. VISUALLY LOOKING AT A GAS CAP WILL NOT TELL YOU GOOD OR BAD. THEY CHARGE 10.00 AND WILL TELL YOU IF THE GAS CAP IS LEAKING. DONE IT TOO MANY TIME WITH DAIMLER CHRYSLER.
Nov 11, 2008 | 2005 Dodge Durango
Smelling gas at when stove is in prelight then going away
Welcome tkrogers,
You said,smelling gas at when stove is in Pre-light then going away.
In some stoves this is normal as long as it is a slight smell and it goes away when the stove or oven ignites.
You know gas really has no smell, but this smell is added for our safety!!
What is the Make,year ,and Model number of your range?
The gas must start somewhere until the flame ignites it.
So we smell a slight smell of gas until it burns.
Thanks,
Huuum
Please remember to lave a solved rating before you leave.
Oct 11, 2008 | Frigidaire Kitchen Ranges
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
64 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
