Question about Mint Automatic Floor Cleaner
Cleaner only goes backward, flashes 5 red lights
Turned power on, put cleaner on floor and pushed the teardrop button. Cleaner starts but only goes backward for a short distance, then a red light flashes 5 times and cleaner shuts off
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
Cannot push vacuum forward on new area rug. But will work pulling backward. Still works on old area rugs and floors.
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your DC25 on this particular new area rug. As you've confirmed the vacuum works as normal on other rugs and hard floors, it doesn't sound like there's a fault with the vacuum itself.
As lightweight area rugs are not fixed to the floor, it's possible for the rug to lift and seal against the soleplate of the cleaner head, due to your DC25's powerful suction. As this will reduce the amount of airflow entering the cleaner head, you may need to use more push force than usual when vacuuming this type of flooring.
We would encourage you to check directly with the rug manufacturer, as they'll be best placed to provide information on correctly caring for this particular floor type.
If you'd like to discuss the issue you're experiencing with our experts, you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 23, 2015 | Dyson DC25 Animal Upright Ball Bagless...
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
Clogged Sebo automatic X-1 vacuum
Hi There,
So when this light is displaying, it's says "Bag Full or Clog" on the indicator. If you have changed the bag, and it's still showing this light, it means that you either have a clog in the vacuum, or your filters are dirty, which is reducing the suction and making the machine think that your bag is full. If your machine is actually cutting off, this indicates that your machine is definitely clogged, or something is stuck inside which is causing the motor to not get air flow, and cauing the machine to over heat. When it shuts off like this, it's a protection system that prevents any damage from happening to the motor when it can't breathe and starts to overheat.
My guess is that there is probably a clog in the machine somewhere, or the filters are dirty. Here's what you may do to diagnosis the machine, and try to isolate the clog to find out where it is in the vacuum.
Step 1. Remove the hose and wand assembly from the vacuum cleaner completely. You may do this by pressing the two tabs on the end of the hose that plugs into the vacuum cleaner:
With the hose and the wand removed from the vacuum, it should look like this:
Step 2. Now turn the vacuum cleaner on and check to see if the red light comes on while the hose and the wand have been removed. If the light comes on, then this indicates that your filter is dirty (or the PCB electric board is bad if the filter is clean) and needs to be replaced.
Step 2. Re-attach the hose and wand back on the vacuum, but just the end of the hose that goes into the vacuum cleaner, leave the wand out of the vacuum cleaner so it looks like this:
Turn the machine on now as if you were using the attachment hose to clean corners or above the floor and see if the red light comes on here. Also listen to the noise the motor makes and see if the noise changes when you put the hose back on the vacuum cleaner. If the red light appears, or if the motor makes a higher pitched noise now, then this indicates that you have a clog in your hose or wand. You may verify this by remove the hose again from the vacuum, and also removing the wand from the hose by pressing the hose release button on the wand and pulling the hose out of the wand. Look down both of the parts and see if you can see thru both sides. If you're not able to see light through the hose, or the wand, this indicates this is where the clog is. You may take a metal clothes hanger, and try removing the clog this way.
Step 3. If the red light did not display with the wand not inserted into the vacuum, put the wand back into the vacuum cleaner as if you were vacuuming the floors:
Turn the machine on, and see if the red light comes on in this position. If the light does come on, then this indicates that you have a clog in the bottom of the vacuum cleaner. To check and see the clog in the bottom of the machine, I find it easiest to remove the upper bag housing from the vacuum cleaner completely so you're just looking at the bottom power nozzle of the vacuum cleaner. There's a button at the bottom of the machine that is either a grey, or yellow color depending on what color your vacuum is. Simply press this button in, and lift upwards on the handle or the bag housing at the same time:
Step 4. After the bag housing has been removed, turn the lower part of the vacuum upside down so the brushes are facing upwards. There's a little orange flap on the bottom of the machine that is actually a clog port. Almost every time there is a clog in a Sebo, this is where I typically find the clog. Open up this orange colored trap door, and look to see if you can see any obstruction or clog underneath of here:
Step 5. You may rotate the neck of the power nozzle part towards you so that you may look inside to see if you see any obstructions inside:
Step 5. You may also remove the brushes from the vacuum and look behind the brushes at the suction port, or the area where the suction goes through the vacuum to see if you see anything obstructing the suction here.
These are really the only places that the Sebo can get clogged. If you checked all of these areas, and the red light is still displaying, this means that your PC Board that controls this indicator has gone bad, and needs to be replaced. If this is the case, please just reply to this repair using the comment field, and I'll be more then happy to help you through the replacement of replacing the PCB Board.
I hope this answer was helpful to you, and you were able to find the clog and fix the problem. If you found my repair helpful, please be sure to rate the repair by clicking the 4 thumbs up icons in the top right hand corner, or by leaving feedback for me. This is really what keeps repair professionals continue to post free repair solutions rather then just the paid questions. It's really appreciated when you take the time and do this if the repair was helpful.
Thank you so much,
Jan 29, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
Red light on then cuts out how do i unblock please? lost the manual.
Hi There,.
Aug 09, 2012 | Sebo X4 Bagged Upright Vacuum
Will not turn on when plugged in
Hi There,
Thank you so much,
Jul 23, 2012 | Sebo X4 Bagged Upright Vacuum
Blinking lights - no roller ball movement
I'm sorry to hear you're having difficulties with your DC28. If the red on/off switch and all 4 white floor setting buttons are flashing, you'll need to reset the machine by turning it off for at least 30 seconds. This should resolve the issue, but if the buttons continue to flash, please check the cleaner head and brushbar for obstructions as shown in the video below.
For any further advice or assistance, please call us free on 1-866-693-9766 or email us at askdysonUS@dyson.com so we can help.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
The on switch light and all floor height buttons continually flashing
I'm sorry to hear you're having difficulties with your DC28. Four white lights flashing along with the red on/off switch indicates that the cleaner needs to be reset - you can do this by turning the cleaner off for at least 30 seconds before attempting to turn it on again.
If you're unable to resolve the issue by resetting the cleaner, it's probably best if you get in touch with us directly so we can run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Sep 10, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
My purple Dyson Animal (without the ball) isn't working correctly. When I turn it on, the red power light, as well as the medium pile buttons flashes. When I first turn it on, the brush rotates for 3 to...
I need help repairing my Dyson. I cannot push the buttons down to select Short pile/Medium pile or bare floor. The buttons will not push down at all. It will not allow me to select anything. I have very short pile carpet so it does not pick up that well.
Oct 23, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Mint Automatic Floor Cleaner Logo
16 people viewed this question
Top Mint Vacuums Experts
JoeVacs
Are you a Mint Vacuum Expert? Answer questions, earn points and help others
