Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Why do I smell gas when the hoses are good? - Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
  • Maytag Master
  • 8,220 Answers
That stove has sealed burners. It is not uncommon for folks to try and raise the top and when they do they break the lines on the front to the front sealed burners. To lift the top ya must twist each burner a quarter turn then get it out far enough to remove the screws which hold the burner tubing in place. Once them screws is removed you can lift and look for leaks. I have also seen places where the oven tubing bends get a small leak down to the oven valve. One more thang to look for is a dim ignitor. if it is dim and weak it might be allowing a tiny amount of gas to come out before ignition. Bubble test for leaks you must!!
Posted on Dec 26, 2013
I got a 2000 Buick regal gs what would cause me to get really bad gad mileage and you can smell gas in the car
First and most important, check the fuel rail,injectors and fuel lines to the engine and make sure you have no leaks. If you can't see the injectors on the back side, get a mirror and good light. This needs checked. Next check the fuel pressure regulator. pull the vacuum hose off of it and smell for gas in/at the hose. If you smell gas, replace the regulator. Next check all the vacuum lines broken ones cause a lean mixture and the computer will throw more gas to the engine. You must have the check engine light on, Check for codes. If it isn't check for codes anyway.
Dec 30, 2014 | Cars & Trucks
Gas smell
I had a similar problem with a 2000 Kia Sportage. The check engine light came on all the time. Part of the problem seemed to be the fuel cap having high pressure. Then one fine day I smelled gas fumes from the rear of the vehicle. After removing the fuel pump cover in the rear behind the seats, I found gas coming from a hose from the tank. I then (sometime later) I found a crack in another hose. The hose was from the filler neck. It caused a lack of vapor pressure and a smell. The check engine light now was off.
Mar 20, 2014 | 2001 Kia Sportage
I have a 2001 grand caravan sport bought used had it for two weeks started to smell gas engine light came on before I smelled gas checked that it is the o2 sensor so I changed it then smell got worse I see...
Some one is going to need to put the van on a hoist and get a really good flashlight and check it carefully. I had such a problem, and found it to be the hose between the gas filler neck and the gas tank was split. I have also had a few cars that had a hole rusted in the gas tank.
Be blessed as you chase this problem.
May 21, 2013 | Cars & Trucks
Gas smell inside outside the car. poor gas mileage
Check the fuel hose and clamps from the filler to the tank .check hose for cracks . The smell will probably be strongest in the boot.
Mar 22, 2013 | 2005 Saturn VUE
I can smell gas outside car. No gas drips on ground. I Just filled gas tank and as I went around a sharp turn, a car in back of me reported gas comming from rear of car. When air is on max, we can smell...
Have the filler hose checked for a break. The hose that connects the filler tube to the gas tank. Sounds like it is loose or broken, when you turn the corner the gas slops out of the tank cause the filler tube is not connected good.
Jul 17, 2011 | 1997 Mercury Grand Marquis
Is it normal to get a faint gas smell when you hook up you'r gas dryer?
Absolutely. Your dryer runs on gas, and the gas kicks on when the heating element engages. It should be so faint though. If you smell it continuously then check your connections with soapy water, if their is a leak then shut off the gas and try using soap pipe dope, or teflon tape on the threads, then recheck. My guess is its the regulator near the heating element. Good luck
Feb 21, 2011 | Kenmore 77632 Gas Dryer
I have a kenmore 70 series gas dryer. the dryer works pretty normal except the clothes take a little while longer to dry and they all smell badly of natural gas. i opened it up and and i can see the...
Check the vent hose for kinks . Also check the exhaust at the outside to make sure it has good air flow to the outside . A dryer either heats or not . Due to it heats , the only possible problem is vent hose blockage .
Sep 23, 2010 | Kenmore Dryers
Smelling gas fumes in passenger cabin. Cannot detect any smell under hood. Does it have a cabin air filter ?
There are rubber gas line hoses under the hood & after a number of years they tend to leak ever so slightly. They are under the hood to the passenger side. You may need to replace these fuel lines. There should be a cabin filter but you must take the wiper motor screen off to get at it & it is on the passenger side. Good luck!
Feb 02, 2010 | 2000 Chevrolet Blazer
I have a gas smell that seems to be coming from engine compartmen
you HAVE a gas leak, the best way for this problem is to use your senses of smell and sight.
Look for gas leaking at the same time smell for the strong smell of gas and locate the area.
Aug 11, 2009 | Toyota Camry Cars & Trucks
Smell of gas fumes underneath vehicle near fuel tank
I also have a 2004 XC90 and a couple of months ago I had the exact same probelm... after multiple visits to my dealer's auto shop they figured out that it was the fuel pump. They replaced the fule pump and the smell disappeared. Good luck!
Oct 14, 2008 | 2005 Volvo XC90
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
66 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
