Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
I need the best picture settings for Sony KDL-40S5100
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
barbu51
  • 566 Answers
SOURCE: how do i change to 1080p on my kdl-40s5100
Hi dragon
To answer you question;
Your tv is able to process signals that it receives from dvd`s,cable box,computers etc. at up to 1080p.
But it does that automatically when it detects/receives that signal.
The only thing that you can change is the format that it will display it, like 16:9 , 4:3, panorama, zoom etc.
hope this help
Posted on Mar 15, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
djchillsnyc
  • 151 Answers
SOURCE: kdl-37w55/57 sony bravia
hello, try tightening your antenna connection this happens when your signal input cable is fualty or loose check that first. then try all other connection that come from your cable,sat reciever or antenna hook up. if your using a digital reception device or digital antenna check those connections to. and be aware that digital reception has interuptions and they depend on the distance between you and the digital signal broadcast station, sometimes storms and atmospheric conditions may cuase a brief lapse in the signal.(stutter) what are you using for a reception? satelite, cable or a digital antenna? hope this helps
Posted on Jun 04, 2010
  • 171 Answers
SOURCE: I have a Sony KDL-40s5100,
I think that there is a problem with your INPUT/OUTPUT BOARD also know as the ANALOG BOARD
try the other inputs to see what happens
when your using the cable input try to open the menu it should open if it is just the analog board
but if not then you might have a digital problem
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!!!!!!
Posted on Oct 07, 2010
I have a Sony Bravia model=KDL-40S5100 that has a static sound coming from the speakers, the picture is just fine and everything else works great it's just the static sound
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
May 29, 2017 | Sony Televison & Video
I have a Sony KDL-40S5100 that has very dark colors and major ghosting or trails when there is any movement on the screen.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 01, 2015 | Sony Televison & Video
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
My dish network remote isnt working with my Sony Bravia LCD model KDL-40S5100
You didn't mention the model of the Dish receiver, so here are some common Sony codes. To reprogram the remote, press and hold the "TV" button on the remote until it stays lit. Enter one of the following codes and press "#". Check all of the functions. 500,640,652,756,758,781,783,795,796,797,798,806,807,837,844,845.
Apr 19, 2011 | Televison & Video
What type of audio connection is needed to connect headphones to the Sony Bravia, model KDL-40S5100
The problem wiht this TV is that it does not have headphone output jack (spec: http://www.reviewed.com/product/Sony/Bravia-KDL-40S5100/specs.htm)
You will have to use:
1) AUDIO line out jacks (RCA RED and WHITE JACKS) of the TV connected to small headphone amplifier to drive your headphone.
2) you will have to trun off the TV built-in speakers using on screen audio set up.
3) Set the TV audio line out to be VARIABLE instead of FIXED level if you want to use the remote control to control the level of the audio output feeding the headphone amplifier.
As you can see, it is real simple setup.
Example of headphone amp;
http://www.radioshack.com/product/index.jsp?productId=2732095&CAWELAID=107598976
Same one at AMAZON: http://www.amazon.com/Upbeat-Audio-T613-BNC-Boostaroo-Application/dp/B000EIWCFE/ref=pd_sxp_grid_pt_1_0
Notes: you will need RCA plugs to mini-stereo phone jack adapter since this unit does not have RCA INPUT JACKS.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jan 12, 2011 | Sony Televison & Video
I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony KDL-40s5100, I can see a picture and watch a movie through when using my blu-ray player, but when I go to watch cable TV, I get audio but no picture.
Oct 07, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Im trying o connect my dell inspiron 6400 to a Bravia LCD KDL-40S5100 and the screen shows that there is no signal with the computer, even though the cable is properly connected. I have another DELL PC...
The difference between the 5100 and the 6400 is the video card inside. The 5100 has an ATI videoand the 6400 has Intel graphics.
Try going to the Intel site to download new drivers for the Intel graphics. There is a driver checker on their website.
Mar 20, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do i change to 1080p on my kdl-40s5100
It automatially adjusts to the signal it is getting. You have to be connected via HDMI to a source that is putting out 1080P (Blu-Ray, Playstation, etc)
Peace,
Mar 15, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How to improve picture quality sharpness?
PICTURE QUALITY IS USUALLY A FUNTION OF IT'S SOURCE. GARBAGE IN GARBAGE OUT.
IF YOU HAVE COMCAST OR SATELLITE AND IT IS NOT HD, YOU NEED TO HAVE AN HD SIGNAL FOR THE BEST PICTURE. THE BEST INPUT IS THRU THE HDMI INPUT. IF YOUR UNIT HAS A GOOD PICTURE WITH YOUR DVD UNIT, THEN THE HAVE A SIGNAL SOURCE ISSUE.
Dec 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
560 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
