Question about Double Power 7 inch Tablet with 8GB Memory
My Double Power EM63 will not cut on once it gets to the DOPO loading screen.
I have tried resetting it. Nothing works.
How do I reset my 9" dopo tablet
Press to reset the tablet. Insert a paper clip or other small object with a narrow tip into this reset hole at its bottom.
25829542-zbf0iuqrbs3vw1pstdxvekqu-4-0.jpg Gopakumar Gopalan Google
Aug 20, 2015 | Double Power DOPO M-975 9" 4 GB Wi-Fi Grey...
I purchased a dopo 10 in. tablet for my son and it is completely locked, i need help please, it just says to many pattern attempts, then goes to enter email info, yet kicks me back to the lock screen.
Hi J ....it sounds like you will need to do hard reset.this may be due to the latest app you installed or a failed update from google.
first... Switch off the tablet.....second hold the power button and volume up together for at least ten seconds....third let the tablet do what it does till you see the android robot with red triangle....wait....then input from the menu offered ....usually you will need to reset the tablet to factory install.this is a pain but in future disable auto updates if you can.. Tell it to let you manually install.once you have the tablet back sign into you google play account.that should remember your purchases and help you reinstall .unfortunately you will lose all the private info and pictures.for what it's worth if you do decide to make another pattern draw it on some paper and photograph on another device.please vote if this helps you.have a nice weekend.
Feb 07, 2015 | Double Power DOPO M-975 9" 4 GB Wi-Fi Grey...
How am i suppose to unlock my password on my tablet?
this is how its done in most android phone and tablets. hope this helps
Jun 30, 2014 | Double Power DOPO M-975 9" 4 GB Wi-Fi Grey...
My ematic 4gb EM63 7" is stuck in trying to complete turn on process, cannot get p.ast the logo and blinking lights. I simply cannot turn it on. I've only been using it since Jan 2014. Been trying to
So I guess nothing else to do but to get it to boot from a SD card with Android 4.1 on the SD Card, It appears your's is corrupted, there is a number of sites where you can download along with directions to make an Android boot card. Hope this gets you up and running.
Apr 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
Can't reset ematic dual core tablet em63
A hard reset is a last resort, by doing a hard reset you will start all over (pending your skills) you will loose all aps/ data you may have had. Remember the basics on a soft reset you need to hold volume up button and then hold power on button it takes some time for the unit to boot, this is intentional.
Mar 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
Stuck on loading, won't go pass loading even after resetting
First thing to do is try a soft reset. Hold volume up button and whilst holding it, hold power on button till it boots up. Really hope this works for you.
Ematic 7'' dual core em63
You will likely have to reset your tablet to it's factory settings using the key sequence.. it'll mean you'll have to re-load your data and programs but you'll have your tablet back. Been there more than once... Oh well.. here's the procedure:
Press both the volume up key and the power button key to turn the tablet off completely. Once it's off, press down the power button and the volume key together. Release the power key and hold the volume up key until the "Factory Reset Menu" appears. It looks kind of like a robot with it's chest hatch open. Use your volume up and down buttons to move the selection to "Factory Reset" and press the power button to select it. The tablet will reset itself and you'll be back to a brand new tablet.
Mar 22, 2014 | Tablets & eReaders
Double Power 7 inch Tablet with 8GB Memory Logo
538 people viewed this question
Top Double Power Tablets & eReaders Experts
ka4iup
ka4iup
jeff5may32
Andrew Taylor
Andrew Taylor
Are you a Double Power Tablet and eReader Expert? Answer questions, earn points and help others
