Question about GE JKP20 Electric Single Oven
Oven comes on for no reason followed by the start beep
The 350 oven light start light comes on followed by the start beep - the only way to stop it is to flip the circut breaker - when turned back on the oven will work as usual and then the start beep starts again - 2006 GE Wall oven - Model #jkp20cof633 - any suggestions - thanks
    Problem Solver:
  • 5 Answers
Yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
Posted on May 17, 2009
Display went out on my whirlpool RBD305 oven and then it stopped working
You will need to replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Whirlpool RBD305PD Electric Double Oven
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
We have a kenmore model# 911.47692100, oven with a self-cleaning cycle that does not want to work. Following the instructions we push CLEAN, the 4 hour display comes on, we push START and the LOCK DOOR...
The oven self clean heats the oven in excess of 450 degrees. It will not begin until the door is properly closed and the slide lock goes completely home. This is to prevent anyone being able to get into the oven until after the cleaning cycle is done. When your "door lock" indicator blinks and beeps, try the door to see if it is really locked. If not, shut off the system and try to find out why it is not locking properly. If you find the reason and fix it, it will probably work properly.
Jan 01, 2018 | Ovens
What does blinking beeping F2 mean?
Hello there"
The F 2 error that you are getting is telling you that the temperature sensor is going bad and needs to be replaced the temperature sensor is what senses the ovens temperature say you have it set for 350 when it is at 350 the sensor tells the oven to stop heating up and when it gets to a certain temp below that value it will make the oven heat up again
it looks like this
May 21, 2010 | Magic Chef 9815 Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
What does the F1 alert mean?
Hello jiverson,
Welcome,
You said, your get a recurring F1 beep even after I press "cancel" I worked with the oven for about 2 hours trying various combos of opening the oven, pressing cancel and trying to perform various functions (light, clean, bake, broil, etc.) to no avail. I got it to stop for about an hour at one point, but it started right back up again. It also seems that every now and then the oven light will come on all by itself during one fo these alerts
Please send me your complete model number including the single diget at the end of the model number.
For example: FGB24S5AW1
Then I can be sure!!!!!!!!!!!
Waiting your response. I'll check for it through out the day!
And get back to you as fats as possible so you can take care of it Monday!
Huuum
In some ovens It could be failure of your, EOC (Electronic Oven Control) failure
Oct 19, 2008 | Frigidaire FGB24S5A Gas Single Oven
GE JKP20 Electric Single Oven Logo
151 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
