THE PROBLEM I WAS ASKING ABOUT IS ON A DUPLO DC8 MINI COLLATING MACHINE, NOT A TV.
  • Pat Dunne
    Pat Dunne Dec 28, 2013
    I have 2 DUPLO DC8 Mini Collating machines, both with the same or similar fault. They will not power up when switched on. The power is getting to the Board at the base of the machine, which I think is the power supply unit. There are two fuses on that board and they are both OK. However the machines are lifeless, and the control panel does not illuminate. When you switch on the machines it is as if they were unplugged. Because the same type of fault has occurred in botgh machines, I was wondering if this type of machine has a history of this type of failure, what is the cause of it and what is the cure. I look forward to your answer. Incidentally, both machines are mechanically perfect. Thank you. Pat Dunne.
Please help me, I have a Duplo machine DP L500 and it's giving me service call E001. What would be the problem?
    ewol3i Apr 01, 2012
    main motor error..check main motor boards fuse at the back of the machine or the timing belt might be damage
  • Joseph Nov 28, 2013
    check the encoder sensor
ERROR CODE E001 DUPLO DP C120 Duplo Office Equipment Supplies
The manual is here, although it does not mention error codes.
http://www.toshiba-sa.net/Documentation%20%20Duplo/DPL-500/DPL-500_Instruction_Manual.pdf
Duplo machine DP L500 error E001 Google Search
Mar 07, 2018 | The Office Equipment & Supplies
What does collating mean?
gathering together of items at a single so that it easier to sort and review
as in gathering data from different files into one folder for processing
Nov 02, 2017 | Office Equipment & Supplies
Duplo DF-520 N Manual
late, but...
try this one: http://downloads.udpnet.com/filedb/pafiledb.php?action=file&id=84
Mar 02, 2012 | Duplo Office Equipment & Supplies
I have a canon image runner 330 s, My question is. It is asking me to conact the finisher? What is a finisher and where is it located?
A finisher is a whole seperate piece that sits beside the copier or sometimes it sits partially in the copier. Its used for collating and stapline mostly. There are also other options you can get( hole punch, folding, etc.) If your machine is telling you to connect the finisher and you dont have one i would try restarting the whole machine. Turn the main power of the copier off and let it stay off for about a minute. Turn it back on and see if the message goes away. If that doesnt work let me know and ill look into it further.
Mar 13, 2011 | Canon Office Equipment & Supplies
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Mar 19, 2009 | Duplo DP21L Copier
Got error code e104 duplo DP-460H
Jan 08, 2009 | Duplo DP460H Copier
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
