Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Control Panel Doesn't Work
The lights on the control panel do not light up when pressed. Machine will prime, but does not brew coffee. Can the machine be fixed easily or is it not fixable? Do you know how much it might cost to fix the control panel?
  • 3 more comments
  • brian_mcconv May 28, 2009
    There are lights that light up on the top row. The water light comes on when the temperature is hot enough. The water light will come on if the tank is empty. But no grinding or brewing. Not sure how to use the bypass.
  • John May 11, 2010
    Solution #1 is a good start. If that works you are in luck.
    If not...
    Is the cup warming surface of the machine working? The cup warmer has to be working for the grinder to work. This will help determine why the grinder is not working.
    For the bypass...The bypass button has s symbol that looks like a coffee scoop. To brew using bypass, press the bypass button and put one scoop (1 Tbsp) of ground coffee in the bypass chute. The chute is about half way back on the right side of the machine and has a small rectangular lid which lifts off. The press the desired coffee size. This will help determine what the problem with the brew group is.
    John
  • bansheracer May 11, 2010
    Hi
    Do you have any lights on the top row of the machine that are lite?
  • John May 11, 2010
    I need more information to determine what's going on. Does the display light up or is it dead? Does the the grinder work? Can you brew coffee with the bypass?
    Board failures are very rare so that's the last place to look.
    We repair these machines in the Houston area and the average cost to repair is under $100 if that is any help.
    John
  • Ernest R
    Ernest R May 11, 2010
    A cpu board for the machine might run for about $280 thats a rough estimate.
  • 1,089 Answers
Do you have any of the left 3 lights on the top row? If you have the one that looks like 2 arrows pointing towards each other do this
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
Posted on May 28, 2009
Panel won't light on Saeco Magic Delux
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Parts for your magic deluxe
May 29, 2011 | Saeco Magic De Luxe Espresso Machine
How do i turn off the descaling light
Hello info 11220,
I understand you need to turn of the descaling light on you Saeco Magic De Luxe Expresso Machine. The only thing you need to do after you get done descaling the unit is to hold down the steam button for 5 seconds and the light should go out. If you have any more questions please feel free to ask.
Thank you for choosing FixYa.com
Justin
Mar 09, 2011 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe - water icon is flashing red and thus cant make coffee
Turn the knob ON to let the water flows out constantly until the red light goes off.
Jan 20, 2010 | Saeco Magic De Luxe Espresso Machine
My saeco machine wont turn on
if you lift the top of the machine and look at the control panel ( you might have to pul the front too) you will see a fuse in the front.
Most likely that one is broken
Aug 10, 2009 | Saeco Magic De Luxe Espresso Machine
The red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Apr 22, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light
The is a plastic "flag" on the side of the grout bin which may have broken off, if so you will need to order a new one from Gaggia UK in Halifax
Dec 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
1 would be the finest. I wouldn't recommend going under 2 though.
You risk clogging your grinder and machine under 2. There's also a dosage control when you open the door on the side. + means a bigger dosage or puck.
Hope this helps.
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Pump won't shut off
Hi Shamin,
You have to replace the printed circuit card.
Mar 30, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
461 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
