Question about Crayola Marker Airbrush Set
My crayola air brush won't spray. How do I get it to spray
Clean the cpn14xc9
I think you are asking how to clean the coils on this unit. I would not advise taking it apart unless you really know what you are doing. If the coils are dirty just buy a good can of coil cleaner spray. Let sit for a while and brush the coils with a soft bristle brush. Tooth brush works good. Don't be forceful and bend the fins, it will restrict the air flow and reduce the efficiency of the unit. After you clean it with the spray and brush spray with warm water to remove the remaining coil cleaner from the coils. You may need to repeat this process more than once. Good luck, hope I helped you.
Sep 28, 2014 | Haier CPN14XC9 14000 BTU Portable Air...
CRAYOLA AIRBRUSH ONLY SPRAYS AIR
Did you check for obstructions on the airbrush?
Dec 26, 2013 | Crayola Marker Airbrush Set
I can't get my crayola marker airbrush to spray
The video doesn't tell me anything! I must conclude that the tip of the airbrush is not allowing paint to flow. First see if the air pump is working by removing the tip completely. If it is then the tip can be cleaned with the tools in the airbrush kit!
Dec 31, 2012 | Toys
How do i clean coils at condenser and evaporator
Blow through with compressed air or nitrogen. Failing that brush clean with a hand brush, then spray with weak detergent solution and rinse with water.
Aug 06, 2012 | Dometic Rooftop RV Air Conditioner
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Where can replacement parts be brought for the Crayola Magnetic Double Easel
n order to make the art trays stay on the easel (several people have complained that they easily fall off), you have to reach behind (inside) the easel and snap them on. You don't just sit them on; they snap in place. Do this and they won't keep falling off. : ) if thats the problem....there are no replacement parts...
May 18, 2011 | Crayola Toys
A crayon melted in my back car seat, how can I remove it?
Try this..
??¦Use a dull knife to scrape any of the debris off.
??¦Apply WD 40 to the stain and let it stand for five or so minutes. (Spray lubricant /oil)
??¦Use a stiff bristle brush to loosen the crayon.
??¦Wipe off with a clean terry cloth.
??¦Reapply as necessary.
??¦Apply liquid dishwashing detergent to the area with the stain.
??¦Work into the stain.
??¦Wipe clean with clean terry cloth.
??¦Rinse with a damp sponge.
??¦Allow to air dry fully.
May 13, 2011 | Crayola Classic Color Pack Crayons...
I need a replacement mold for a Crayola Crayon Maker CODE #04-9020.
Hi, replacement mold can be found easily on amazon, click here and take a look: Amazon com crayola crayon maker mold. Best of luck
Nov 28, 2010 | Crayola Toys
Crayola Marker Airbrush Set Logo
66 people viewed this question
Top Crayola Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Crayola Office Equipment and Supply Expert? Answer questions, earn points and help others
