FAILS TO POWER UP WHEN SWITCHED ON
My problem is with powering up the machine. It began with the machine going on and off rapidly when switched on. It would eventually settle down and work normally. This has now stopped and the machine fails to power up when switched on. As far as I can figure , the problem would seem to be on the circuit board. I don't have sufficient knowledge to check that out. When the machine was going on and off the lights in the control panel were doing likewise. They are now failing to come on. There is a flap on the bottom of the machine that moves when the machine is switched on, and that is the only sign of life there is. Fuses etc. are OK.
    New Friend:
  • 39 Answers
You may have some bad capacitors in the power supply or bad surface mount fuses in the LCD inverter.
Posted on Dec 26, 2013
4 Suggested Answers
SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
Posted on Nov 11, 2007
  • 157 Answers
SOURCE: Philips LCD TV 37PF5520D/10. TV will not switch on.
philips has a problem with bad caps(swollen)in power supply-try shopjimmys.com enter model number-scroll down til you find power supply-order it simple to put in.if they do not have it write down part number then google it to find one--you also can change the bad caps yuorself if you are handy with a soldering iron
Posted on Sep 11, 2009
budmrtn
  • 11361 Answers
SOURCE: The power switch fails to
Unplugging it from the outlet for about an hour to let it reset itself first, if it still does not work then It may be in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board, you can try disconnecting the power cables to the backlight inverter board to see if you can get the TV to come back on with sound but no pictures.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 22, 2010
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Haotion 125 bad earth lights working incorrectly
intermintant loss of power to headlights clock air conditioning 2001 toyota avalon ! solution....new alternator and new battery fitted.
Oct 04, 2012 | Cars & Trucks
I was sewing everything was fine. When I changed to zig zag it also worked but, when I switched to straight sewing and pressed the foot peddle the machine began to make a beeping sound and it won't go...
If the needle was on the down position when you switched stiches, this could have caused the problem. Raise the needle completely, power the machine off for 30 seconds, then power back on... Did that fix it?
Jun 22, 2011 | Singer 7436 - INGENUITY
Hoveround MPV 4. Joystick problem?
Count how many lights are flashing to determine the root cause of the problem. Here is alink that may help:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
The abrupt stop may have knocked something loose.
Apr 09, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
Display lights flash
I have just posted the same problem about the lights flashing rapidly, I have just gone to investigate my machine and switched it off and on again at the mains and so far it has resolved the problem. Hope this works for you.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Failure to switch on
fails to switch on again despite repeated attempts.
this is due to power supply failure.
please call skilled tech to fix it.
Oct 14, 2007 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
