Question about Philips 42PF7220A 42 in. Plasma Television
Philips TV will not produce any audio
42PF7421D/37 WILL NOT PRODUCE ANY AUDIO. THE TELEVISION WAS IN STORAGE FOR OVER A YEAR. THE PICTURE IS GOOD; IT JUST WILL NOT PRODUCE ANY SOUND. PLEASE HELP!
  • 36 Answers
Using the process of elimination ckeck the audio/vidoe (monitor) out, if that works we need to look at the audio output stage, if the tv has a earphone/headphone socket try that, if that works it will be the speaker, if it doesn't it will be either the audio ic (check Dry Joints 1st) or a capacitor in the audio stage, the fact that it's been sitting for a while would indicate a capacitor. it's ahrd to diagnose unless you eliminate the I.F and audio processing stage, also check that you have it set to the right area frequency, eg: depending on where you live, check the selection "NTSC-PAL-Secam" if it's on the wrong selection it maybe that the audio frequency is set to the worng region. Hope that helps with the limited information to work with. Phil
Posted on May 18, 2009
Philips TV model no.42PF7421D/37 has green line on left and clear picture goes to snow in 3 to 5 minutes
the tcon boar or the lcd panel is faulty. can confirm by replacing the tcon board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 04, 2017 | Philips 42PF7421D 32 in. LCD HDTV
I want to raise the picture on my Philips 42PF7421D/37
It is hard to understand exactly what you want to do. Here is a link to the product support site for this item. You can download all the manuals and software updates. You may also want to review the FAQs section. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=42PF7421D/37
Feb 03, 2015 | Philips Televison & Video
I have a Philips 42pf7421d/37 lcd tv having problems. When you first turn the tv on it seems to work perfectly fine. About 5 minutes later my picture cuts out and I get a scrambled screen. Turn it off and...
First, you need to make sure all of the vent panels on the tv are clear of obstructions. Heating may be causing the problems. Next, get a hold of a clean, dry source of forced air and blow out the inside of the case and the internals of the tv.
Jan 22, 2013 | Televison & Video
Philip 42pfl7432d/37 has sound, but no picture, what is wrong?
Tv turn on now,pictures only flashes few sec. than dies have audio left only?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
May 11, 2011 | Philips 42PFL7432D 42 in. LCD Television
I have the problem philips 42pf7421d/37 stop the tv and blik the red light only ? please help me
Are you saying the tv does not come on when you press the power button as it should? If that is the case - the philips tvs have a known issue with power supplies and if you have experience with electronics I'd say open it up and check the power supply for bad capacitors (bulged/leaking or busted caps) if you have component level experience replace them then try your tv again - ive fixed many philips tvs with this problem.
thanks,
michael
Apr 18, 2011 | Philips 42PF9431D/37 TV
I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
Dec 08, 2009 | Philips Televison & Video
I have a Phillips LCD tv model #42PF7421D/37. and
I know on the plasma TV's it was a matter of updating or downloading and re-installing the firmware/software for the TV to fix the issue. Go to the following page and if the model you have is indeed a 42PF7421D/37 download the software on the page. Make sure you follow the installation instructions to update the software otherwise the set will become a 150 lb paper weight.
&scy=US&slg=AEN&sct=LCD_TV_SU&cat=TV_CA&grp=SOUND_AND_VISION_GR&session=20091111140139_64.85.227.44&ctn=42PF7421D/37&mid=Link_Software&hlt=Link_Software">Philips Support Page
Nov 11, 2009 | Televison & Video
Good picture, no sound
Hi, sounds like a Philips flat panel could not find a manual for this model, if you have tried both DVD and cable box and both produce no audio. & check the speaker is turned on in the menu of the TV. then you have a problem in the audio amp circuit of the TV, Philips had a problem with some back in 2003 and it was the SSB board that needed repair or replacement. It may be cheaper to just buy a stereo surround system and run both cable box and DVD straight to the surround system.
sorry could not be of more help.
gd lk
Eric
Aug 13, 2009 | Philips 50PFP5332D 50 in. Plasma...
Screen Shift PLZ HELP
burn in run  a white screen
Jun 06, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
