Question about Primo Grills And Smokers Primo 601088 Hot & Cold Bottom Loading Water Dispenser
Primo water cooler
The water runs slow not a fast stream like it did when first purchased. What is causing this? It is only 1 year old.
Primo top loader water cooler
Is there a filter? If so it may need replacing.
May 05, 2017 | Refrigerators
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
We have a primo water dispenser, model # 900183 and the water is dispensing as one slow stream not a fast full stram of water as it use to. how do we fix that?
Had the same problem. I tried cleaning it as instruction on the copany website with bleach and water. I also unplugged it for a couple of days to see if the lines were frozen. Finally out of frustration I put my mouth on the water dispenser, pushed the button, and sucked some water out and spat it out. After that I did the same thing again but blew into it instead. I did this a couple of times and my water dispenser went from a trickle to flowing like the day I first got it. Also, you should probably clean the water dispenser after doing this, just saying.
Apr 27, 2013 | Refrigerators
Where is the reset switch on a Primo water cooler model YL1136S
My Primo Model:YL1136S Hot Water Quit Working How Do I Repair It
Aug 24, 2012 | Baby Gear
Primo water cooler
I JUST BOUGHT A PRIMO BOTTOMLOADING WATER DISPENSER AND ITS BEEN ON ALL NIGHT AND THE WATER IS WARM. I LOOKED ON THE BACK TO SEE IF THERE WAS A WAY TO TURN IT UP BUT FOUND NOTHING. PLEASE TELL ME WHAT TO DO. RNMALIN@ COMCAST.NET
Jan 06, 2012 | Primo 900172 1.0 Gallon Industrial Water...
Remove sediment from my pool deck drains
I would go with a smaller sewer snake as long as you work slow,pvc can become brittle over time. Work the snake in conjunction with water to help flush debris from the line.
Nov 21, 2009 | Ace Hardware Plumbing
Slow water run for cold water
slow water run could be caused by the filter on the cold water hose is clogged by granite or mineral deposits
1. turn off the water to the cold hose
2. drain water out of hose and detach from washer
3. get a water spray bottle and set to strong stream not spray,
spray the filter that goes into the machine, this should clean out the debris that is clogging the line hold a small container to catch water when you spray if you see black specks it granite
4. after it runs clear reattach hose and turn the cold water back on that should solve your problem, it did the trick for me
Dec 21, 2007 | Kenmore 24032\24036 Top Load Washer
Primo Grills And Smokers Primo 601088 Hot & Cold Bottom Loading Water Dispenser Logo
78 people viewed this question
Top Primo Grills And Smokers Water Filters & Coolers Experts
Tom Chichester
Are you a Primo Grills And Smokers Water Filter and Cooler Expert? Answer questions, earn points and help others
