Question about GE 3.9 cu. ft. Stainless Steel Capacity Washer GHWN4250DWW
GHWN4250DOWW HOW TO REMOVE THE AGAITATOR
Ge GHWN4250DOWW washer tub seems loose and "off kilter" making a horrible racket when spinning
Could be bad shock absorbers. Google that washer model number, and at the same time shock absorbers, and see if it has them. If it does, I bet their broke. Ebay 10 - 30 bucks. easy fix. Good luck
Oct 17, 2013 | GE 3.9 cu. ft. Stainless Steel Capacity...
Frigidaire stackable fills up and will not agitate but the final spin works fine. already replaced timer & pressure switch but it still wont agitate
Hello Jeremy,
Does the washer do anything on the agaitate cycle...and sounds being made or is it just sitting their till it drains and spins??
You ya hear what sounds like it should be agaitating yet it doesn't ya would need to check the agaitator drive block which is under the agaitator or also check the the transmission pulley
I want to say check the timer if no noise but i know its new so its a mechinal problem as opposed to a electrical one
GENE
Sep 27, 2011 | Frigidaire FEX831CS Top Load Stacked...
How to remove the agitator on a GE ProfileWPSR3120W0WW? The utube video (describing a bolt at the bottom) does not describe accurately what we have. Softener dispenser removal only yields a clear plastic...
Your washer is close to the one in the video but as you know not exact..that agitator coupler shown in the video bolts down under the agaitator. To remove your agaitator which locks into teh agaitator as shown just pulls off....so to remove your just grab the bottom of it and pull straight up and off of the agottaor coupler.
GENE
Sep 07, 2011 | GE Profile WPSR3120WWW
Removal of the Agiator
To remove that agitator all that needs to be done is grasp it from the bottom of it very near the bottom of the inner tub and tug and pull it off...it has a center hub under of the agaitator and the agitator fits on to that hub by several locking tabs and simply pulling up on the base will allow the agaitator to come off.
GENE
Sep 06, 2011 | Amana NAV6800AW Top Load Washer
All cycles on my washing machine work, but machine will not agitate. What are possible solutions to fix the issue? It is a Hotpoint, top load, model # is vvsr1070daww
The most probable thing causing it to not agitate is going to be stripped/broken agaitator coupler.
The video will show you to take out the agitator and check for a defective agaitator coupler
http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Sep 05, 2011 | Hotpoint VVSR1070D Top Load Washer
How do I remove agitator assembly
This youtube video will show ya how to remove the agaitator (and replace the DOGS kit)
http://www.youtube.com/watch?v=0GQh8JLqVv8
GENE
Aug 27, 2011 | Whirlpool LSR9434PQ Top Load Washer
How do you remove the agatator on model lsq9549lwo
remove the top of the agaitator, some have a cap some a detergent cup
remove the clear inter cap and o ring
the bolt holding the agaitator can be accessed then with a nut driver
remove the nut and lift the complet agaitator out of the machine
May 16, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE 3.9 cu. ft. Stainless Steel Capacity Washer GHWN4250DWW Logo
35 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
