Question about Dynex EN-21669D Remote Control 1061531
My dynex en-21669d wont turn on with the remote is there any other way to turn it on
My DYNEX 32" wont give me any sound from remote or tv but changes channels
remotes do not have speakers in them and you might have turned MUTE on . having no way to see it personally there is not much we can do
Aug 03, 2016 | Dynex 32 in. LCD Flat-Panel HDTV
I have dynex en-21669d universal remote how do i set up my Pioneer dvd/cd receiver ?
Instructions should have come with the generic remote but often generic just do not work with many systems
Oct 14, 2014 | Televison & Video
Dynex 40" model DX-L40-10A tv remote control En 216690
Codes to check with Dynex brand TVs are 0853,0875,0828,0816,0842. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and proceedings to some popular model remote control are given.
Mar 04, 2013 | Televison & Video
How do I turn my Dynex 40'' LCD TV 1080P on with out the controller?
Have the remote tested----our shop uses a tester--if remote is bad we usually can fix it for 10 dollars or less.
A digital camera with a LCD display can also be used in a dark room--remote pointed at it and buttons pressed---camera display will flash faintly in response.
Failing that try to locate a replacement remote (good luck with this brand).
May 16, 2012 | Televison & Video
I have a dynex 19 inch tv that wont turn on can you help
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Dynex+DX-LCD19-09+
Please post back what you find
Dec 18, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Sometimes my tv dynex 32" wont turn on the light is red then i unplug it for a few seconds and it turns on
Look at the power supply first it may be going out; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
You can look here for parts: www.shopjimmy.com
Dec 17, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
32" Dynex No Power, Power on/off light will not light up
Check the power supply module first for blown fuse, bad capacitors, etc.
Please post back what you find.
Nov 12, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Oneforall remote wont work with my dynex tv!!
I used 0463 for my 19 inch DYNEX LCD TV. It's the code for Emerson & Admiral. :)
Jul 23, 2009 | One For All URC-4021 Remote Control
My t'v wont read my remote!
You will need to call the Dynex customer support and ask them for help with this problem. The problem sound like the television is having a problem with the main read controller for the remote control. This is a problem for a service center.You can call Dynex customer support at this telephone number 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of your television and the problem you are having with the remote control reading circuit. I hop this information helps you with your problem.
Apr 12, 2009 | Dynex DX-LCD37 TV
Dynex EN-21669D Remote Control 1061531 Logo
27 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
